Time for solar-pumped water
   / Time for solar-pumped water #1
chatcher
Raceland, Kentucky
NH TC35DA, JD X324
This is the year I'm jumping into solar energy. It will be a learning process.
I have two projects on the drawing board, one of which isn't very "tractor" intensive, but the other will have enough seat time to qualify.
The first is to provide water to my home during an electrical outage. I currently have a fairly shallow well with a 240 VAC jet pump and pressure tank which is dependent on grid power. I will be changing to a Grundfos SQFlex submersible pump which runs on anything from 30 to 300 VDC or 90 to 240 VAC. The plan is to run it from a 48-volt bank of batteries charged by solar (PV) panels, with the ability to switch it back to AC if the battery system fails. The pump is pretty expensive compared to an AC submersible, but it is supposed to be very efficient and long lasting. The tractor part of this project will be limited to digging post holes for the homemade solar panel mount. I shouldn't need to do any digging for water lines since I plan to run water through one of the existing jet pump lines and power wiring through the other.
The second project is to provide water to my garden from a nearby pond. I'll use a solar panel for this, too, since the greatest need for water will be on clear, sunny, summer days. I don't plan to use a battery for this, just one 12 VDC PV panel and an RV-type diaphragm water pump. And a linear current booster in between to help start the pump under load. I am not sure what I will do with the water once pumped, I actually have two plans. I have a 100-gallon bladder-type pressure tank left over from a previous project years ago. If the bladder is still good, I'll pump into it during the day and have 100 gallons of water under pressure whenever I need it. If that doesn't work out, I'll pump into 55-gallon drums in the loft of the barn near the garden and use gravity for watering. For this project I'll have to trench between the pond and the garden/barn area and dig a hole for the solar panel mounting post.
I could have run electricity to the garden, or water from the house for that matter, but the idea of freedom from the grid appeals to me.
I'd be interested in any tips from anyone familiar with these things, especially on constructing solar panel mounting arrangements that won't blow away.
   / Time for solar-pumped water #2
I hate to cast any stones.. but.. maintaining a battery bank as a 'what-iff' battery backup, will be expensive... batteries go fallow when not used.. and I think you will find that you may not get a good return on battery service life vs cost, plus the cost of the new expensive pump, plus the cost of the solar panels. It mightbe a nice 'long term' idea for an 'EOTWAWKI' scenerio.. but in common practice.. not great unless you are ready to go solar whole hog.. house and all. ( when fuel cell technology comes out wide spread.. solar will become viable... )
on your panel powering a pump.. if you are pumping up a pressurized tank.. I'd hate to see the cost of the solar cell that would power that...
If your well is shallow enough for a hand pump.. I'd invest my money into one of those with a bucket over it for use when needed, and then buy a pto or stand-alone gen for my tractor to run everything else..
soundguy
If you have a pond.. what about a windmill pump?
Cast away, please - I'd rather debug here than under the house.
Soundguy said:
batteries go fallow when not used.. and I think you will find that you may not get a good return on battery service life vs cost, plus the cost of the new expensive pump, plus the cost of the solar panels..
The batteries will be charged daily, or at least on sunny days. I hear you on the cost. Definitely the cheapest way to pump water is to hook up to the grid. But in an emergency the grid isn't there, so from a practical standpoint, since there is no high place for me to store water, it's either batteries or a generator for backup. A generator and fuel storage isn't cheap, either, and I'm more confident in the long term availability of sunshine than reasonably priced fuel. My first set of batteries are "free", so proving the concept won't be as costly as it could be, and the new pump will run on grid power if necessary.
An RV-type diaphragm pump ($50 or so plus $100 for an electronic current booster or MPPT) should give me 45 psig, about 1 gpm, under 5 amps (12 vdc). I'm going to try a single 62-watt panel (about $300) and double up if I absolutely have to. That should be enough water to fill whatever storage arrangement I come up with on an average sunny growing season day.
For the house, the object is to keep the running water, uh, running. After spending the money on solar equipment, I don't want to have to tell Mama she has to pump water for her bath!
If I had some high ground for a water storage tank I'd consider that, although I don't usually have much wind, and the windmill wouldn't be cheap, either.
Good points, but you haven't quite talked me out of solar yet...
As far as a whole house solar system, I'm getting my feet wet. If the house water system works as planned I may add an inverter to run a few other things, which would probably lead to more panels, which would lead to more batteries... I'm not ready to make that commitment just yet.
   / Time for solar-pumped water #4
Ok I have a 6 SQF-2 pump running on solar power. It pumps 4 gallons a minute most of the time running at 48v 240 watts of panels. It works great with no batteries. Provided you pump in to a storage tank and not a pressure tank. I highly reccommend that you not try to use the Grunflos pump to fill pressure tanks. You need to pump into a storage tank and then use a seperate pump to pressurise with. I have several neighbors that tried that and all found that it did not work well and went to storage tanks and seperate pumps tp pressurise with . My system pumps into an 1800 gallon storage tank and then i use a shure flow 12 folt pump to pressurise my pressure tanks. The pressure system is 4 40 watt panles charging two golf cart batteries. The shure flow pump will pressurise 45 lbs OK. I use a regular pressure switch as opposed to the built in switch that comes with the shure flow pumps. My system has been running like that for 5 years. I pump from a 280 ft deep well with water level at about 100ft the pump is set at 140 ft.
As far as the pond pump I don't do that but my experience is that a one single panel (unless it is a really big one ) will not run the shur flow pumps. You need 5 amps or better to run the pump. You would/could use a single panel and one deep cycle battery for that purpose provided you did not pump all day and gave the battery time to recharge part of the day.
I do not know where you ae getting your prices But my well pump was $2700 pump, controller, wire, and pipe, installed. Did not include panels which I already owned.
   / Time for solar-pumped water #5
Rob (3RRL) has a pretty good write up on solar as his new house is off grid.
I think the solar was about the same cost as getting grid power at the wrong end of $100,000. But that's from my porus memory, so who knows ?
jb
   / Time for solar-pumped water #6
jb
Wow... that sounds like quite a system. I read in a magazine (popular mechanics?) about someone living off the grid in VT because the cost of running power to their place was too expensive. They still ended up running Generators part of the time, but learned a ton.
It would be interesting to read 3RRL's write-up.
   / Time for solar-pumped water #7
I'd love to have a solar powered pump from a more shallow well down below (creek area is 100" below the house here). A submerged solar-powered pump would give you less trouble than your present jet pump. Just run it every once in a while to keep things going. You might need a battery to keep an even power input to the pump. I run my electric fence on a little 5 watt solar panel. All I did was slap the solar panel in place and connected it directly to the 12v battery that I was using (and having to recharge about once/month) before. In the winter, I bring the panel up and mount it in front of my carriage house to power a battery charger and inside light. Just took it down below again a few days ago. It's just mounted on a crooked pole that leans it at about 45 degree angle to the sun and leaning directly south. On the carriage house, I just made a little wooden bracket that I screw it to there. It's, of course, a smaller panel that what you likely need for your pump.
Ralph
Jimbrown said:
Ok I have a 6 SQF-2 pump running on solar power...highly reccommend that you not try to use the Grunflos pump to fill pressure tanks...several neighbors that tried that and all found that it did not work well...I pump from a 280 ft deep well with water level at about 100ft...
...my experience is that a one single panel (unless it is a really big one ) will not run the shur flow pumps. You need 5 amps or better to run the pump...
...my well pump was $2700 pump, controller, wire, and pipe, installed...
Good to hear from someone with a Grundfos helical pump installed and working. As far as the pressure tank goes, my well is a lot more shallow than yours, so I think I will have more pressure. Looking at the pump curves for your 6 SQF-2, at 240 watts and 4 gpm you should have about 150 ft discharge head, or a little under 20 psig after your 100 foot lift and pipe losses. The same pump at the same power in my application should give me over 50 psig, so I hope to not need the booster pump. I should know very soon, I will be installing the pump in the well shortly using the existing AC power source and in addition to learning whether or not it can handle the pressure tank setup I can read the power it's using in watts right off the control box panel.
I paid $1700 for an 11 SQF-2 pump, CU-200 control box, wire splice kit, and shipping. No wire pipe or labor included!
For the garden I shied away from the Shurflo pump for the exact reason you said - by using a smaller (and cheaper) pump I can hopefully get by with less panel, and the slower flow rate shouldn't hurt me given the relatively small amount of water I am able to store. If I were depending on it to provide water for my shower I wouldn't be so cheap!
RalphVa said:
...A submerged solar-powered pump would give you less trouble than your present jet pump...You might need a battery to keep an even power input to the pump...
One of the reasons I'm doing this now is that my jet pump is just about worn out. The reason I need the batteries is that I have no way to store enough water under pressure to get me through the night (and cloudy days). I would love to use gravity to store the energy but in my situation it isn't an option. The ideal situation would be to pump water uphill while the sun shines, and use the water 24x7, no batteries required.
   / Time for solar-pumped water #9
Some things to consider. The pump will not start if there is not enough current to run it at 500rpm or better. For my pump that is about 100watts. It will pump at about 80 or 90 but normally is running at about 180 watts. My pipe and wire cost was $432. This pump I have on 1 1/4 PVC. My last pump was a Dankoff it ran for 6 years. I had in on black plastic pipe and installed it myself. Self installation is not difficult.
   / Time for solar-pumped water #10
I think it's great your going solar and will be off the grid for well power.
My new house will be totally solar with the exception of my well, simply because my well is away from the home and is 700 feet deep. I will use my porpane generator for well service.
I am surprised at some of the costs given for Solar Power, I currently have a 1,000.00 system that powers my small cabin and expect to spend no more than 15,000.00 on the system for my home. It's just two people in my household but currently on the grid and a 1,500 square foot 50 year old house I use only 429 KWH a month. So in a new home with tons of insulation, propane appliances and a lot of natural light I plan on getting by with a 4.5KW system. I purchased my solar stuff so far from Backwoods Solar Electric Systems they all live off grid and have good advice.
I think you will find that it doesn't take that much water pressure to fill a pressure tank. My well pump only is rated at 5gpm and it has no problem filling my 40 gallon pressure tank. Now that I have the 10,000 gallon tank at 100ft I no longer need the pressure tank but it worked great for almost two years putting out over 60lbs of pressure.
A inexpensive low energy pump for your garden can be found at WalMart the Attwood bilge pumps put out good pressure and don't cost more than 30.00 bucks. They are designed for a 12 vold stystem so no inverter or even a battery would be required as long as the sun is shining.
Good Luck
Derik
2006 FREIGHTLINER CST120 (A53843)
2006 FREIGHTLINER...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
Ranger Welder (A52377)
safety baskets (A53421)
safety baskets...
2019 Freightliner M2 (A53422)
2019 Freightliner...
