Time (expereince) heals (almost) all wounds.
   / Time (expereince) heals (almost) all wounds. #1
prs
Platinum Member
Logan, WV
JD 650, Ventrac 4500Z AJ02248
I want to thank all you folks for helping me along. THANKS!
I have posted about a lot of issues:
The "squeak"? No big deal, just greased the right places (where ever those are). ;-)
Getting hung-up on down hill side guy wires? Sure was glad to know I was not the only one. So far, so good, just knowing what to avoid helps. Setting the steering back to it tightest turn radius regardless the dualies also helped.
Weight transfer not returning to lowest level after work is done? That was simply sticks, weeds, and grass clippings collecting and packing in under the spring; would not allow spring to lay down all the way. Leaf blower after working keeps it nice and clean now. My mowers are both rear discharge.
Slope gauge? What a joke. I just don't pay any attention to it and ride seat of pants.
Fast idle below spec? Took 4500Z's advice and got a photo tachometer. Its not slow after all.
Fuel use? It was excessive at first, but much, much better now. Some improvement might be the machine wearing in, but I suspect the operator getting experience was biggest factor.
SDL fade? I did not understand how it was supposed to be, I thought it would be like cruise control when the neutral assist was switched off. Now I get it and NO PROBLEMO. The neutral assist thing is off and has not been used since.
I thought it needed locking differentials? Well, I still think it does. If it loses traction, only one side of either axle drives. I understand that with the articulation, locked axles would not steer efficiently. Heck, nothing steers well when a locker is engaged, but you only engage them intermittently. Yep, an electric locker feature would be a good thing when things get slick. Probably $$$$ though.
The positioning of the SDL and AUX levers allows the AUX to be pressed fully right when I cross a slope that is down hill to my right; i.e., gravity slides my big ole butt against the levers forcing the hydraulics to be stressed until I get off the slope. This is a real issue and I have done one mod that helped a good bit. I removed the right arm rest and changed its spacers around to move that arm rest about a half inch to the left. My big ole butt now slides against the arm rest sooner and is better held away from the AUX lever. I may get an automotive trim shop to rebuild that arm rest to be longer to more fully protect the AUX. I also have made a conscious effort to scoot over to the left as far as I can and brace myself when entering long side slopes that slope away to the right.
The only unsolved mystery issue is that the front right lift arm raises its load before the left one and thus the implement when raised is always higher on the right than the left. I see no adjustment to make it lift level, but most of the time the implements are working on float, so no real big deal. But it would be nice to have it right.
prs
   / Time (expereince) heals (almost) all wounds. #2
The front hitch may be sprung. I suggest checking it with a level when no implement is attached. Then report it to your dealer.
Be careful in extending the right arm rest forward. It might interfere with the AUX lever when traveling in reverse.
My technique for limiting movement of my butt to the down side when mowing across slopes is to use my upslope elbow to pinch the upslope armrest against my body.
   / Time (expereince) heals (almost) all wounds. #3
All in all how do you like your Ventrac??
Jack, how about a really dumb question? With tires equally inflated, parked on level pad and implement off, would it be best to have lift arms in mid position, up, or down? I guess I could record all of the above.
Murphy, so far I like it a lot. I still use my John Deere 650 to pull, till, grade, and haul stuff because I already have all of that stuff. But mowing and light brush cutting is all Ventrac now. The Ventrac is much more safe for slope mowing.
prs
I think the lift arms may be put together crooked. Its been that way from the get-go.
The left arm rest did interfere with the AUX lever going into reverse and when lifting the outer mowers of contour mower at same time. Changing the spacers resolved that issue.
Your bracing method will be tried by me. I have been grabbing the ROPS to the left or putting my right hand into the cup holder at the right, thus using my foot lever to control speed and direction.
prs
   / Time (expereince) heals (almost) all wounds. #6
I would check all three positions using a standard level laid across both arms.
Weather permitting, I will check the lift frame tomorrow as Jack described. Might even try getting a pic of the uneven lift before removing the contour mower and then after.
prs
I could find nothing wrong to explain why one side of my implements is lifted before the other. I placed a level on the floor and bubble is centered. I placed the level on the top of the hood, bubble centered. I placed the level on the lift arms in raised, lowered and mid positions and all level. Every thing works OK, so I just don't care any more. I have the pics on my Samsung phone, but it totally escapes me as to how to get them from there to here. Seems to be some secret or I am just to stupid.
prs
   / Time (expereince) heals (almost) all wounds. #9
prs it would be very helpful for us to assist you if you could just post pictures of your slopes and mechanical issues. Please consider finding a friend who can help you through the steps of downloading photos from your smartphone to your computer and then posting them here.
   / Time (expereince) heals (almost) all wounds. #10
I second what Jack said. You could also go to the play store and get the tractorbynet app and easily upload the pictures using it. That's how I post pictures here from my Samsung smartphone.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2012 Chevrolet Captiva Sport SUV (A50324)
2012 Chevrolet...
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
