tiltmeter mounting location
   / tiltmeter mounting location #1
bher
Bronze Member
Lancaster, PA
NH TC 29D
I just got a tiltmeter from the link on TBN. I have a TC29D and was wondering where others mounted the meter on their Boomers. I looked around for a place and nothing jumped out at me. Suggestions appreciated.
   / tiltmeter mounting location #2
Here's where I mounted my TiltMeter on my TC25D. I used the new mounting method of double stick tape.
   / tiltmeter mounting location #3
Brant, I was in such a hurry to experiment with the tiltmeter on my property that I just cinched it down with two plastic zip ties on the bar that runs over the top of my dashboard from the loader frame. It works fine, and I've never made it more permanent.
Leef
   / tiltmeter mounting location #4
mike does the hood hit the tilt meter when you open it up
   / tiltmeter mounting location #5
Nope.
   / tiltmeter mounting location #6
On the FEL bracket
I have a TC-40D, and the 16LA loader brackets are perfectly vertical, which is a requirement of the tilt meter I have. And just a little wider than the meter. Peel and stick. It is a little low and off to the side, but out of the way for the 99.999% of the time I don't look at it.
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
GOOSENECK COUPLER (A51248)
GOOSENECK COUPLER...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
2025 INDUSTRIAS AMERICA 7014 70"X14' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
John Deere 772-A Grader (A52384)
John Deere 772-A...
