tilt trailer cushion cylinder
   / tilt trailer cushion cylinder #1
howdog52
Can I use a double acting cylinder to build a cushion cylinder for my tilt trailer? How do you plumb this? One hose from port to port? drill a small hole in the piston? Thanks
   / tilt trailer cushion cylinder #2
I messed with this about 20 years ago, I tried using a shock absorber from a Semi trailer. It did not work to my satisfaction.
I would think the trick with the double acting cyl. would be to restrict the flow from one side to the other at the right rate to give you a cushion. That would not seem to be difficult to do initially.
I hope you can tell me if you figure it out. I don't have the time to mess with it.
   / tilt trailer cushion cylinder #3
fill with oil only with the cylinder retracted. put a valve on the line from one end to the other that you can open to your satisfaction. If you fill the cylinder with it extended, you will have more oil in it than it will hold once retracted.
2019 MACK PINNACLE (A45333)
2019 MACK PINNACLE...
PALLET OF EXTENSION CHORDS AND JUMPER CABLES (A45333)
PALLET OF...
Ripper Attachment (A45336)
Ripper Attachment...
2010 TEXMEX  UTILITY TRAILER (A45333)
2010 TEXMEX...
YANMAR SV08-1B (A45333)
YANMAR SV08-1B...
VOLVO FUEL TANK (A45046)
VOLVO FUEL TANK...
