Tilt steering wheel issue...FYI
   / Tilt steering wheel issue...FYI #1
duffer
Platinum Member
Aiken, SC
'16 Mahindra 2538
Hi guys,
Just wanted to let you know about an issue I experienced with my tilt steering wheel (on the 2538, but I suspect many other models are similar). Being an old fart, with bad knees, I tend to "help" myself onto the driving platform using the step and pulling "somewhat" on the steering wheel.
Well... a few days ago, I broke something, and the tilt steering wheel became a 4-way tilt, not just up and down.
I took the dash off, and a stabilizing bracket (made out of cheap & weak pot metal) broke allowing the stabilizing pin to fall off. No way to re-weld it, and I wouldn't want to anyway due to the thin gauge "steel" they use. Luckily there is another pre-drilled hole just above the stabilizing pin location, where you can insert a good quality bolt, washer and nut. Easy fix, but just a PITA. Loosened upper and lower dash components, and moved them out of the way, and inserted the bolt, washer and nut and re-assembled dash. Took about 10 minutes is all, but still... :mad:
So the moral of the story is, don't pull yourself up using the steering wheel like I did. Although, my fix is much better than Mahindra's OEM bracket.
   / Tilt steering wheel issue...FYI #2
Most “old farts” have good info- this is no exception!
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
