tilt steering on 3520
   / tilt steering on 3520 #1
bud4410
kingsville, maryland
jd 3520 HST open station turf tires air seat jd 997 ztrak 72"
since new, the tilt steering on my 3520 has slipped. i happened to have it back to the dealer recently and they installed a new bracket, the one with the teeth that you unlatch to move the steering up or down. they said the teeth were worn from slipping. it did improve it but not cure the problem completely. the two springs on the latch are kind of weak so i got an old screen door spring and cut two small springs from it the length of the originals and bent hooks from the end coils. installed them alongside the originals, two on each side. it made lifting the latch real stiff but so far it has yet to come unlatched even if you pull yourself up from the seat with the steering wheel. seems the stronger springs are keeping the teeth meshed unlike the weak original ones. hope this helps someone else who may have the same problem. cheers...........bud
   / tilt steering on 3520 #2
Just read the post I have a 4520 and same problem 1st. Doubled the springs worked for a while then would slip when trying to get off the tractor. Good way to lose footing.
Thanks for suggestion of stronger spring.
easy to get to just need deeper teeth on bracket.
ken
23311 (A51694)
23311 (A51694)
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
TEREX RT665 MOBILE CABLE CRANE (A51406)
TEREX RT665 MOBILE...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
