Tilt Cylinder
   / Tilt Cylinder #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
Have a CK20 and would like to add tilt cylinder to the 3 point hitch. Have any of you guys done this and if so what length hydraluic cylinder did you use. Also was it a single action or double action cylinder. I have a little angle to my drive and hate getting off tractor to adjust.
Thanks!!
Eddie
   / Tilt Cylinder #2
search for tnt or top n tilt or hydraulic toplink. Much has been discussed. I'm using what came with a hydraulic 3ph fork lift that I bought. It has no check valves. Not sure how long it is. I'd guess something like 14 - 20 inches, max travels. It works. But, many buy the CCM one. They supply specifically for your model tractor.
   / Tilt Cylinder #3
It will work out best for you to use a 2" bore x 4" stroke cylinder. Cut off the ends and then cut off the ends of your stationary side link (usually the left side) and weld them to the cylinder. You'll be all set.
Good luck
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2016 Takeuchi TW40 Wheel Loader (RIDE AND DRIVE) (A50774)
2016 Takeuchi TW40...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
