Tilt cylinder leaks down on 773C
   / Tilt cylinder leaks down on 773C #1
jcalla
Triangle, VA
I was using my 773C today & all of a sudden I noticed the tilt cylinder on my grapple bucket leaks down real fast. My question is how do I determine if the problem is the cylinder or the valve body?
JPC
   / Tilt cylinder leaks down on 773C #2
It's messy, but tilt the bucket/attachment all the way back then remove the line from the base end of cylinder then start machine and try to tilt back again and watch where the oil comes from, cylinder or hose. 99% cylinder.
   / Tilt cylinder leaks down on 773C #3
JPC
With a leak like that, does the relief valve activate when you go full extend or retract?
Does it do that with engine on/off or both.
   / Tilt cylinder leaks down on 773C #4
Non-contact infrared thermometer with a laser pointer. Fast, mess-free troubleshooting of cylinder problems. Identify a blown cylinder packing, prove that a cylinder is sound, find the bad piston seal in a pair of cylinders plumbed in parallel without spilling a drop of oil. Works every time for me.
Thanks for all of your suggestions. I found a test procedure in the service manual. However, I am curious about infered testing to locate the leak. Since the oil is hot already, how would it find the leak?
JPC
   / Tilt cylinder leaks down on 773C #6
JPC
Start with cold oil. However, oil rushing past a leaking piston seal (or any small orfice) will generate more heat than the surrounding body of oil or metallic mass that contains it.
   / Tilt cylinder leaks down on 773C #7
I will have to try this next time.
Brian
UNUSED LANDHONOR PHA-16-2C HYD HITCH ADAPTER (A51248)
UNUSED LANDHONOR...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
TMA (A49461)
TMA (A49461)
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
UNUSED FUTURE VR59 59" VIBRATORY ROLLER (A51248)
UNUSED FUTURE VR59...
2007 HONDA TRX250 RECON ATV (A51247)
2007 HONDA TRX250...
