Tiller tilling depth
   / tilling depth #1
Dream Farmer
Western MN
Bobcat CT230
Just wondering if the skids are necessary on the tiller?? has any body removed them in an attempt to till deeper? Would this help or wreck something?
Shawn
   / tilling depth #2
Leave them on. It will prevent wear and tear on the sheet metal and on the equipment. If you are tilling in loose soil the unit will sink down a little anyway.
   / tilling depth
I'm not worried about the wear on the "sheet" metal since that is 1/4 inch steel. what I don't like is where the feet ride there it compacts the soil. I am getting down about 7" but was wondering about maybe getting a couple more out of it for some of the spots like where we plant the taters.
Shawn
   / tilling depth #4
I have wondered about removing the skids myself. I do remember someone on the forum doing that and saying it helped them. No idea what the long term affects would be to the tiller.
MarkV
   / tilling depth #5
I've removed the skids from my King Kutter. It definitely helps get deeper. It wears it maybe a little, but for occasional tilling I wouldn't worry about it at all.
   / tilling depth #6
The top 6" of soil is your most fertile. Going deeper does little if any good.
Potatoes do better in hills. It is better to plant them at about 4" and then pull soil up against the stalk as they grow so the spuds aren't exposed.
   / tilling depth #7
Try it, you may like it. But a steady diet of no-feet tilling will wear the side panels out.
I wore 2 thirds of the feet off of my JD 450 tiller years ago, but I do a lot of tilling.
   / tilling depth
I think this weekend we will find out. I am going to remove the skids and do a test run.. My "garden" is an old wheat field with lot's of nutrients buried below which I want to access with the tiller and the future purchase of a ripping blade.
Shawn
   / tilling depth #9
I'm curious as to why you want to till deep unless your trying to sub soil. I suppose the jury is out. Some say go deep so say don't. but with the exception of sub soiling theres not much a need. IMO
at any rate good luck with your project
   / tilling depth #10
for the depth 8'' to 10'' inches is fine i used to plant taters corn beans peppers beats watermelons they did fine at the depth stick your taters in after they come up bout 6'' start to hill them up when they are done putting leaves on yours hills will be bout 8' to 10'' high and bout 10'' wide i raise garden for 25 yrs
2006 SCHWING P-88 PORTABLE CONCRETE MIXER (A51243)
2006 SCHWING P-88...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
Case 830 Tractor (A50514)
Case 830 Tractor...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
