Tiller Tillers and Stumps
   / Tillers and Stumps #1
webbmeister
Wauconda, Illinois
New Holland TC25D
Well, I spent the day yesterday with a stump grinder (those things are heavy!) and did close to 250 1-4 inch stumps. That's the good news. The bad news is that there're about 500 or more left to go!
Here's my question: Will a tiller make quick work of the smaller stumps, or will the smaller stumps make quick work of a tiller (3PH)? I'm wondering if I should concentrate on the larger stumps with the grinder - I want to be efficient with it, it costs $88 a day to rent it. It also wore me out.
Jim
   / Tillers and Stumps #2
using a tiller to remove stumps will shorten the life of your tiller real fast. it will not work. 88 dollars a dy is cheaper then 1800 for a tiller. you can rent the grinder for 20 days.
   / Tillers and Stumps #3
Ouch. A day with a dozer and stumps be gone.
I wish! A day with a dozer and grass be gone too!
Jim
   / Tillers and Stumps #5
<font color=blue>...will the smaller stumps make quick work of a tiller ...</font color=blue>
Yes...! /w3tcompact/icons/eyes.gif
Ok... maybe the tiller will do 2 small stumps and then self-destruct... /w3tcompact/icons/crazy.gif
Jim... that brand new compact tractor you just bought will make lots of work easier... /w3tcompact/icons/wink.gif
...just sometimes maybe not faster... /w3tcompact/icons/smile.gif
(just remember when you start to get frustrated over the amount of time the current job is taken... take a moment and look at that "rusty shovel" leaning up against the building you used to use...) /w3tcompact/icons/blush.gif
   / Tillers and Stumps #6
I have used several methods for small stumps. You may be able to pull them out with a subsoiler or a box blade scarifier (basically hooking the stump out of the ground). Take it slow and easy. Sometimes I had to try it at different angles to get it to work. I mounted a field cultivator sweep on a middlebuster shank once and used that for digging out quite a few small stumps. If you have any of these implements it might be worth your time to try it.
When I had several hundred small stumps (2"-6") to remove I waited until I had other dozer work and had the operator push them all into a pile for me. Only cost $50 on top of the other work I had for him.
   / Tillers and Stumps #7
Jim,
Do you really have to get them out? Would cutting them off close to ground level so you could mow be good enough? I've got a very small area with similar conditions, but it's not near the "yard" part of my property, so I just used my chain saw to take all the stumps down to ground level and will mow it to discourage new growth from the stumps. I also learned how to sharpen my chain as an added benefit from this exercise!
Chuck
   / Tillers and Stumps #8
I have a Sthil clearing saw, perfect for cutting trees, stumps etc. off flush with the ground. Then you could mow right over them.
Nick
Amen to the comment about the shovel!. Same for the wheelbarrow, the 22" mower. and any other instrument of torture I can manage to retire.
Thanks John!
Jim
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2015 Chevrolet Equinox 2LT SUV (A50324)
2015 Chevrolet...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
