Tiller tiller
   / tiller #1
kramarj
Durand, Illinois
Kubota B7100 w/1630C Loader
has anybody ever made or seen a drag that mounts onto the back of a tiller that levels the ground a little better than the flap on the back? when i till gardens my tiller kind of leaves a furrow, i was thinking about making a small drag that would fill/level it? thank you
   / tiller #2
is the furrow in the center? are the blades all the same size?
   / tiller #3
My reverse tine tiller does that some. Not really a furrow but some low areas here and there especially when the rear tractor tire goes in a high spot and raises the 3 pt on side or the other. Extending the top link so the tiller is not leaning forward helps a lot. Maybe slightly leaning back. Have you tried adjusting the top link?
   / tiller
the furrow is in between each pass, and its not the top link, its just the edge of the tiller pushes dirt away and makes a furrow
   / tiller #5
i don't think theres anyway to not have that happen...its the nature of the beast.
   / tiller #6
Oh I see. Yep, that does bother me some as well. I am sure something could be designed and built to try to smooth that out. It would probably require something hydraulic to change the drag height as each pass has different heights. I doubt it is worth it.
   / tiller
probably not, but i was wondering if you could mount something solid to the tiller and let the "drag" hang on a chain on each end, i think i am going to try that or something of that nature, thanks for the replies
   / tiller #8
If you come up with something, take some pictures and let us see them! Thanks.
   / tiller #10
kramarj said:
it may be a while, but i will try
I used a section of chainlink fence (dog kennel pannel) chained to my tiller when I did my seven acre field. It does take care of the problem but it was a PITA to deal with in corners and forget about backing up. I took it off and attached it to my ATV and went over the field in spots when I was done.
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2019 Bobcat E45 Mini Excavator (RIDE AND DRIVE) (A50774)
2019 Bobcat E45...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Crane Service Truck (A50323)
2019 Ford F-350...
1996 International 4700 Rollback (A47384)
1996 International...
Crate of New Hydraulic Hoses (A47384)
Crate of New...
