Tiller tines
   / Tiller tines #1
Garrabo
Banned
GA
3120,X-575,BX1830,BX22
I have the 42'' hydraulic tiller for my X-575. The tiller works great but im wondering why the tines are almost worn out with only 25 hours on the tiller. do they make a harder tine for this tiller or do I have to stick with the tines that it came with. Im tilling clay with few rocks ..
   / Tiller tines #2
You should be able to put on any tine on that fits.
On my Farmking tiller I have a mixture of land pride and farmking tines. Some have a 90 degree curve while others are more rounded and may not be at 90 degrees.
Dealers or farm suppliers should have a book listing all the dimensions of the different tines available. Measure up your tines and order some that fit. They may not be cheap.
Egon
   / Tiller tines #3
Might check with Deere on warranty.
Sometimes things don't get heat treated they way they are supposed too.
Just an idea, especially with only 25 hours.
   / Tiller tines #4
I am using a 60" Gearmore tiller. I had to replace the tines after two years of use. I talked to Gearmore about getting replacements. The person at Gearmore (theey are in California) said that one customer, a city that uses their tiller to help clean up the beach, replace their tines every week. the lifetime really depends on the soil/dirt. the 90 degree tines are typically called "L" tines and the curved tines are called "C" tines. I replaces my C tines with L tines. The L tines would stall the tractor where the C tines had no problem. There is more tine in the dirt with the L tines. The cost is about $5.00 to $6.00 per tine. My tiller has 40 tines. Use gloves when you remove the old tines, save cutting up your hands
carl
   / Tiller tines
Yeah, I ran into some buried crush-n-run in my back yard.
I guess that can file em down. /forums/images/graemlins/confused.gif
   / Tiller tines #6
they make aftermarket tines if you do a search you might find it here on tbn i forget the website had many models. I'd suspect there would be a problem in the tiller but if you did till hard stuff 25 hrs is alot of wear.. that's probaly 2-3 yrs of avg tilling.
NAMCO GRAIN-O-VATOR GRAIN WAGON (A51243)
NAMCO...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
Wacker Neuson ST31 (A50120)
Wacker Neuson ST31...
2004 Chevy Utility Van (A47384)
2004 Chevy Utility...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
Kivel 3500 Lb Pallet Forks (A50121)
Kivel 3500 Lb...
