Tractor Sizing Tiller Size
   / Tiller Size #1
couchsachraga
Adirondacks, NY, USA
John Deere 4520 cab... formerly Yanmar 336D
Greetings...
In general, what size tiller should one get? Is there a general formula for size of tiller-PTO hp? Or simply try and cover the tractors tracks? As I'm looking around for tillers it's occured to me I should figure out what size to look for /w3tcompact/icons/smile.gif.
Thank you as always,
Couchsachraga
   / Tiller Size #2
Here's a link Muratori's guide to rotary tillers/hoes: If you click on the "category"menu and choose "rotary hoes" then at the "subcategory" menu, you can select
your tractor's horsepower. It will then give you an image of a tiller; click on the image and you will get info. on recommended HP for the tiller, along with dimensions, etc. I assume the info would apply to most other tillers as well.
<A target="_blank" HREF=http://www.muratoriequip.it/inglese/f_prodotti.html>http://www.muratoriequip.it/inglese/f_prodotti.html</A>
good luck
tony w
   / Tiller Size
Hmmmm.... Interesting site. Different tiller models they have seem to have different "recommended hp" ranges (all within 40hp max). I'd assumed (and we know what that means /w3tcompact/icons/eyes.gif!) that X hp meant you could run a Y inch tiller under Z circumstances...but that doesn't appear to be the case!
Thanks for the site!
Couchsachraga
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
