Tiller Tiller size for 28hp
   / Tiller size for 28hp #1
Syncro
Platinum Member
NW Nevada
MF 1532, Kubota B-26 TLB
I may purchase a tiller for the 3 point on my 28 hp MF. Anyone have a suggestion as to size? The ground is completely void of any rocks, pretty much 100% DG. I want to break up the sod which is about 8" deep.
   / Tiller size for 28hp #2
I have read in the past here 5 Hp /foot.
   / Tiller size for 28hp #3
I don't know what 100% DG is but soil conditions really make a big difference in what size you can use.
I have a 50" tiller, use it on a 24hp tractor with 19PTO hp and it heavy moist clay soil it will bog the engine. In dry sandy loam or black loam soil it will churn right through the soil & the sod without any problems. I also have a 30hp tractor, in the same heavy moist clay soil it works great with the 50" tiller but I wouldn't want much larger.
   / Tiller size for 28hp #4
Decomposed Granite - it's fairly common out west (Nevada, California, etc.)
I'm running a 60" King Kutter gear-driven tiller on my 24 Hp (PTO) B2910 in heavy clay soils here. It does fine provided you don't bite off more than it can chew.
I'm running a 60" King Kutter gear-driven tiller on my 24 Hp (PTO) B2910 in heavy clay soils here. It does fine provided you don't bite off more than it can chew.[/quote]
Yes DG stands for decomposed granite, actually its more like black sandy loam close to the sod.
How do you like that KK? would you buy one again? I see that TSC carries them. 5 hp/ft sounds like what you guys are all saying, so a 60" would be about right and is ~ $1200 at TSC. I think it will be reletively easy going in our ground.
   / Tiller size for 28hp #6
Syncro:
I'm running a CCM M-160 (58") tiller in heavy clay, rocky NE soil without problems with my NH TC29DA tractor (29/23+ HP). Jay
2014 Ford Escape (A50324)
2014 Ford Escape...
2000 PETERBILT 379 TANDEM AXLE SLEEPER (A52141)
2000 PETERBILT 379...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
John Deere 7000 12 R 30 Planter (A50514)
John Deere 7000 12...
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 Kubota L2501 (A50120)
2015 Kubota L2501...
