Tiller Problem
   / Tiller Problem #1
IRTEXN
Bronze Member
Cut -N- Shoot Texas
'02 JD 4110 HST
Haaving a little problem with my tiller and hope someone has an idea. 4110 tractor pulling a 647 (4') tiller. Machines are working fine, but as I progress down the row, I get a porpuse effect leaving a washboard behind in the row. Any ideas what might be causing this....Thanks /forums/images/graemlins/confused.gif
   / Tiller Problem #2
Is the ground you're tilling hard packed? If so, you may need to slow down. Since you using a relatively small (4') tiller, hard ground could be causing it to bounce up. If you're going too fast, it won't have time to chew it's way into the area it bounced over, creating your washboards. If the ground is soft, I've got no help for ya. /forums/images/graemlins/frown.gif
Hoss
   / Tiller Problem #3
Run in the slowest gear at max RPM's. hard packed dry ground
   / Tiller Problem #4
You might think I am nuts But In hard stuff I idel the tractor down so It don't bang the crap out of the tiller. This keeps the tiller from jumping up and down.
   / Tiller Problem #5
If the soil is heavy with sod or just plain hard, I take two passes. First one with the leveler door up and the depth set higher, second pass depth is deeper and door is down. comes out like goose down.........
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
