Tiller Mod
   / Tiller Mod #1
romoshka
Clemson, SC
YANMAR 1600, Farmall 100
Pardon my negligence but I neglected to bookmark the thread I am searching. There was on the Yanmar (I think) forum a detailed description of someone modifying a yanmar tiller with slip clutch, longer pto shaft and longer lift arms. Does anyone know where that post might be?
   / Tiller Mod #2
If you haven't bought the slip clutch yet - I suggest don't bother. Assuming you have a Yanmar tiller matched to your Yanmar tractor, they knew what they were doing when they designed them to match. The tiller is light and will simply climb over roots etc. I'm not convinced that we can improve on Yanmar's designs - even if you read here that the first thing every first-time tractor owner does is add a temperature gauge then a slip clutch. On his 'new' tractor that ran 30 years reliably without them. I trust Yanmar's engineering. It simply works.
I run over roots all the time, my work is all in an orchard. No problem.
   / Tiller Mod #3
I agree with California.:thumbsup: I have hit roots, rocks, and huge chunks of concrete, and have broken one tine, but no other damage. The rotation of the tiller is such that it simply climbs over the obstacle and bounces you around a bit. Mind you I have not tried to break it, but it seems pretty workable to me.
Mike
   / Tiller Mod #5
I guess a slip clutch is a good safety item. Every year before I use my Howard tiller, I perform the slip clutch adjustment recomended in the book, grease and fill the gear oil if needed at the same time. Never in the 6 years of using it has the slip clutch ever moved. I marked witness marks on both sides of this clutch so you can tell just by looking. I'm inclined to think California is on the money with this one. I've hit all sorts of rocks and junk with this 5' tiller, tractor it is on is a 33 hp YM3000. I think the clutch could matter more when more hp is put to the drive of the tiller. But so far, my Yanmar doesn't have the hp to slip the clutch except when setting it after the bolts are loosened. Sure could matter on a larger tractor with twice the hp.
Chris
Deere 410G (A50120)
Deere 410G (A50120)
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A50323)
2015 Ram 5500...
Case IH Farmall 75C (A52349)
Case IH Farmall...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
