tiller idea
   / tiller idea #1
todda323
Bronze Member
virginia
yanmar1700bd
Hello all. I'm new to the Buynet and had a question. Any way I had an idea and was looking for some feed back. In my search for a pto garden tiller I have been met with some rather high prices in my area. Has any one ever welded a 3pt hitch bracket to a walk behind garden tiller and used with their 3pt to till. If so I was looking for feed back on the success or lack there of.
   / tiller idea #2
That might work if you can run at a verrrry slow speed. Otherwise you'll constantly stall the engine on the tiller. The one exception would be a diesel engined tiller but one of those would probably run as much or more than a regular pto tiller.
   / tiller idea #3
You should be able to get a Yanmar tiller for your 1700 for less than $500.... Well worth the money... If you havent tried it yet, the Yanmar dealers usually have several on the ground. eBay is another option..
BTW, you'll tear that thing up if you take the time to build what you have in mind.. That PTO has ALLOT more power than it may seem..
   / tiller idea #4
I saw a article in Farm Show where a fella did just that.
Hey...I bet you can get a great price on a Gravely with a rotary plow in Virginia!!! Your part of the country has the best prices anywhere.A two wheel Gravely will smack any tiller silly. /forums/images/graemlins/grin.gif
I'm using my "63 LI to dig the power trench out to the barn here...Look what it does to Whitley County,In. clay....
   / tiller idea #5
Yup!! and it worked fine at slow speeds. But, if that is what you want, why not buy a "Agri-Fab" pull type tiller that has a 5 or 6 horse engine on it and is designed to just pin to the drawbar on your tractor and go till????
   / tiller idea #6
Right on. I bought a pre-owned Yanmar RS1200 tiller (48" wide) last August for $300 from my local grey market tractor dealer. Will use it later this month on my B7510HST to rototill about an acre around the new house. Need to weld extensions on the tiller to accommodate a slip clutch since there's no shear pin on the tiller.
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
2014 TEXAS PRIDE GOOSENECK (A52472)
2014 TEXAS PRIDE...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A52748)
2017 Ford F550...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2023 JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
2023 JOHN DEERE...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
