Tiller tiller gearbox temp.
   / tiller gearbox temp. #1
Newtogreen
Bronze Member
Harpers Ferry,West Virginia
JD 4115
Should the gearbox on a 3 pt tiller feel warm after tilling a garden around 35ft x 120 ft . I don't mean hot to the touch but just warm. Thanks Larry
   / tiller gearbox temp. #2
I would think after running that much it is going to be a little warm. Now if you can't touch it then you have problems.
   / tiller gearbox temp. #3
That is not unusual at all. A new machine that is run the first few time will probably be too hot to the touch until the gears get wore in to mesh each other more perfectly. That is why I like to change a new machines gearbox oil after the first year of use. Ken Sweet
2018 Ford Fusion (A50324)
2018 Ford Fusion...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
Sudenga 10-72 Swing Away Auger (A50514)
Sudenga 10-72...
CFG Industrial QK18R (A50121)
CFG Industrial...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
1998 Cornhusker Hopper Bottom Trailer (A50514)
1998 Cornhusker...
