Tiller Tiller follow-up
   / Tiller follow-up #1
newtothis
Charlotte, Michigan
JD 770
There was a recent thread with tons of good info about tiller brands and all the various stuff to think through. The only thing I couldn't find is my current dilemna: size vs. HP.
I've got a 28 HP JD and keep getting different info from different dealers about what I can handle. JD dealer sez 5' all day long, Kubota sez around 4'. Saw a 5' Rotovator at an auction last week and frankly it scared me, darn thing was a tank! It was a great machine but I'm nervous about purchasing anything right now for fear it will be too large.
I've got between 4-6 acres of former ag. ground I want to put into wildlife plots so I'll be using it a couple times per year on fairly big spaces. I can afford a tiller so I don't want to monkey around with plowing then discing the rest of my life away. Kinda like the idea of just one pass.
The afforemented thread talked me into King Kutter brand at TSC, which I just looked at (AGAINjavascript:void(0)
/forums/images/graemlins/confused.gif ) last night. Going to a state auction tomorrow AM in the hopes of picking up a nice 2 row JD planter so a tiller should get me all the basics.
Thanks for any advice!
   / Tiller follow-up #2
Well your 28 h.p. john deere should handle a 5 ft kk tiller if my 25 h.p. jinma will,,,,,,,,now,,,some tillers offset,so you can cover up one tire track,,tire tracks are kinda important when tilling,,,the five ft kk of mine doesn't offset,BUT,it don't need to cause it covers both tire tracks,,,now maybe it will or maybe it won't on yours,,,if it won't,,,you need to get a five ft,[or even a 4 ft one,]that will offset so's you can cover up one track at least,,,,another thing to think about is tractor speed,,,got to go very slow when tilling,,mines a manual trans,,with a creeper gear,,,,just a couple things to think about,,,,thingy,,P.S.. the 5 ft gear drive kk,,weighs about 800 lbs,,,so it is indeed heavy
   / Tiller follow-up
Speed, hadn't thought it through but never imagined I'd have to be in creeper gear (which I have). Glad you mentioned it.
Why is it important to cover up at least one tire track? I noticed that in the other thread as well.
The local TSC has a 5 footer sitting out there calling to me and I think that's enough to cover up my footprints.
You've got gears on yours? I'm pretty sure the one I was looking at is gear driven as well. I don't have front weights but that shouldn't be a problem should it? The backhoe never seems to present any problems when I have that attached.
Jack
   / Tiller follow-up #4
Well,,if you can't cover up your tracks,,you will have a track in your dirt,,,now,, if you can cover one side at least,,you can put that uncovered track on one side of area and by going in same direction,[by backing up],,all your dirt will be untread on by your tire,,,sounds complicated,,but if you think about it you'll see,,,no,you shouldn't have any trouble with front coming off ground,,if you use a hoe on back,,although not familer with your tractor,,size/weight,,just rember you want that tiller to cover both tracks if possible and for sure at least one....thingy
   / Tiller follow-up #5
I just purchased a 48" KK for my Kubota BX1800 (18 HP) which is 15 or 16 PTO HP so I would think you would be fine with a 5'.
As for front weight, I just kept my loader on while tilling as this baby is ~550lbs so I could see the rear squat when I picked it up. I assume when you have your backhoe on you also have your loader so if you do the same with the Tiller you should be fine.
Good luck,
   / Tiller follow-up #6
Course,,,I was speaking about tilling in a vegitable garden,,,you said you are doing a food plot for deer I guess,,,well it really wouldn't matter that much in that case,,,you just need an inch or so of dirt tilled,,so in your case it won't matter that much,,,BUT,,you may want to use it in a garden sometime,,,so guess it would still apply,,,if I was just planting a food plot,,,don't think tiller would be my first choice though,,set of good disks,,and maybe a harrow type drag should do it,,or just the disks,,,they will cut in most softer ground enough to plant the small seed you will be planting,,than run over it again to cover slightly and mix seed with dirt,,,course if you use disks you got to have a plot thats big enough to go at clip and enough room to turn around in,,,thingy
   / Tiller follow-up #7
Just to throw something out there that I've noticed concerning tire tracks...
My rear tires measure "73" outside. My tiller is a 60" KK. I till using a method Bird mentioned. I make two rows going the same direction with a space inbetween and then till that space. I'm guessing I overlap about a foot on either side in case I get a little crooked with my rows. The only marks I see when I'm done are the skid shoe marks from the tiller.
I was thinking of offsetting using the lower lift arms to move the tiller more in line with one tire, but I don't see a need to after using the tiller like described.
   / Tiller follow-up #8
Well if you and bird say so,,,can't picture it myself,,,I mean if both your tires extend beyond tilling path,,looks to me like you would have to leave tracks no matter how you did it,,,but you say it works so guess it does.......thingy
   / Tiller follow-up #9
one thing I've learned reading these post. If Bird gives a reply you can bet it is right. The tiller will spread loose dirt out beyond the tiller width
   / Tiller follow-up #10
I use a 56 inch Caroni on my 20 hp John Deere if that is any help. I have tilled sod but I usally go as slow as possible. I am glad I got the size I did, it takes out my tracks out.
John Deere 1790 Planter (A50514)
John Deere 1790...
We do NOT accept credit cards as payment. (A50121)
We do NOT accept...
2' Auger Extension (A50774)
2' Auger Extension...
Swict 72" Bucket (A50121)
Swict 72" Bucket...
Land Honor Quick Attach Hitch Adapter (A50514)
Land Honor Quick...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
