Tiller Chain Lube Change
   / Tiller Chain Lube Change #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
My tiller is three years old with about 50 hours on it. Getting it ready for spring, I noticed that the gear lube 80W-90 was caramel colored and sort of milky looking. Thus I drained it and replaced it. I supposed that there was condensation (water) in it. Temps this winter have ranged from around 10 deg F to 70 deg F in short intervals in between.
Yet when I collected the old lube in a glass jar, I see no separation...........just the same, uniform caramel colored fluid. Although it was about due for a change, I'm not sure that the old gear oil was all that bad. Any comments?:confused:
Cheers,
Mike
   / Tiller Chain Lube Change #2
Hi. Mike.
My very very old tiller gets the same color and I see some milky coating on the chain after setting for a long time. I run the unit for awhile then drain the oil.
Seems to be fine. The tiller is about 40 years old and Japanese made. All labels are in Japanese so don't know the brand.
Dave.
Thanks, Dave. It doesn't seem that the subject has much interest elsewise. Hope you have a good year behind the BX wheel. :thumbsup:
   / Tiller Chain Lube Change #4
While its just a "bath" for the chain there's not a thing wrong with your reasoning. "sorta milky looking" is reason enough to drain and replace it.
   / Tiller Chain Lube Change #5
It will be a good and fun year and the ballast box has helped a lot.
I finally got the mole problem under control after trapping 14 moles last year. Had to trap the neighbors moles as well to protect my lawn.
Hope your garden does well. Need to get some rain soon.
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2022 CATERPILLAR 303 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
