Tighten your bolts
   / Tighten your bolts #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
Can't stress enough the need to go over your bolts after a few hours- I found loader bolts were all a "little" loose and one or two that needed several turns to get them tight. A couple on mower were in need too.
Recheck your fluids and regrease zerk fittngs too. I think a couple of the more obscure ones were missed.
(CK30HST, FEL, 72"RFM)
Also one fuse is marked "horn" must be for european use---I dont see a horn-i think europe gets a rear view mirror too.
   / Tighten your bolts #2
The bolts and nuts need checked every so often. Especially on attachments. There's a good bit of stress and vibration put on them.
After getting my CK30hst w/fel from the dealer, I went over everything and found grease fittings he missed. Also checked all the fluids.
I'm a believer in preventative maintenance. I check fluids before I use it and give it a general once over. These toys cost to much to have something break and say, if I only checked before I used it.
   / Tighten your bolts #3
Yup, check everything over you recieve. I neglected to check my MMM gear box for oil when delivered and it siezed up after about 2 hours of use. It was dry as a bone.
   / Tighten your bolts #4
my dealer told me (if I remember correctly) that a CK30HST LB has over 100 grease fittings....................that is alot
   / Tighten your bolts #5
Was he drinking when he told you that? /forums/images/graemlins/grin.gif
RedDog
   / Tighten your bolts #6
no............................but I might have been!!!!!!!!!! .....or close to 100.............so what is the number of grease fittings for a CK30HSTLB?
   / Tighten your bolts #7
Went over mine for the third time after a very big day and with 20 hours on the tractor. FEL pivot pin retaining bolt gone, 6 were loose, 2 bolts on the front axle loose, lower arms on the 3 point had very little grease and I used a 3/4 of a tube of grease from front to back......the FEL just gobbles the grease but I have been running it in very dusty conditions. Resolution from now on is if any kind of loader work is done, no matter how small, grease the pivot pins! Gotta believe now when the manual says to check everything every 10 hours, I'll do it more than that!
   / Tighten your bolts #8
Greg, I've always regreased my loader and backhoe after four hours of use, and nearly always push all of the old grease out rather than just a couple of squirts. Grease is cheap, loaders/backhoes not.
John
   / Tighten your bolts #9
As KiotiJohn said; Push the old grease out.
There's no seals on these joints and dirt and water can get into them. Flushing them with new grease is a cheap way of cleaning and getting all the service you can.
Some people I talk to hate all the grease fittings on equipment. I wish every joint that moved had one, but I guess replacement parts would never get sold.
I have a grease injector needle that I've used on equipment to get into so called sealed bearings. These bearings are still running smooth well beyond their expected life.
   / Tighten your bolts #10
Thanks and that is the plan from now on! Funny how instinct commands your senses. The day before my "Big Day" on the tractor I bought a pistol grip grease gun ( Love 1 handed operation... /forums/images/graemlins/cool.gif ) and a case of grease. I'm now a quick draw greaser! Yesterday was another "Big Day" and another 1/2 tube a grease.
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
Deutz 6806 (A50120)
Deutz 6806 (A50120)
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
