Tight Bolts on BX24
   / Tight Bolts on BX24 #1
Hotwheels
Rescue, Northern California
Kubota BX24, RTV900-Worksite
I have about 50 some hours on my Bx24 now --- find all kinds of uses for it, moving dirt, boulders, carving out a walking path, etc.... I bought the Bro-Tek thumb and installed that and use it for lifting rocks -- nice tool. I also bought the skid plate, but I am having problems loosening the bolts on the rear of the tractor. I am trying to use a 19mm wrench that has a handle about a foot long and I CANNOT get the bolts to even budge. I can do my age in push-ups so I think I have enough strength to loosen anything that is "normally" tight.
Richard at BRO-TEK suggested using an impact wrench. I can probably borrow one from my neighbor, but I am curious if others who have installed the skid plate on a BX24 have had any issues in loosening these bolts?
Thanks,
JR
   / Tight Bolts on BX24 #2
Have you tried increasing your leverage by slipping a pipe on the wrench to increase its length?
   / Tight Bolts on BX24 #3
I also put a Bro-Tec skid plate in. Those bolts were tight on mine also. I used a 1/2 inch breaker bar with a cheater pipe and socket to get them loose. Watch your knuckels when they break loose.
Glenn
I will try the pipe -- if that does not give me the leverage, then I will go radical!
   / Tight Bolts on BX24 #5
Make sure you tighten the whee out of them when you get your skid plate on. Might be a good time to borrow that impact wrench from the neighbor - I don't usually use an impact wrench to tighten bolts unless I really don't want to see them coming off. Those...you don't :).
   / Tight Bolts on BX24 #6
A NICE impact driver. I have a POS for my wheel rotating duties and I can easily out-torque it with a fairly standard ratchet setup...especially if a pipe is involved.
Thanks for the heads up on these particular bolts, though. I'm sure I would have been making a similar post. Hate breaking the pipe out on my pretty tractor.
   / Tight Bolts on BX24 #7
Tight bolts indeed.
Come out easier if the transmission is "cold".
Something about expansion when hot.
I used a standard 1/2" Craftsman socket wrench with no problems. No need for a breaker bar or impact wrench.
Must be variation in how the bolts are installed at the factory -- I tried to loosen the bolts when the tractor was cold, first thing in the morning before the tractor was started. I may get the impact wrench for the tire rotation and to tighten the bolts.
2011 JCB 515-40 Telehandler (RUNS) (A50774)
2011 JCB 515-40...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2853 (A51691)
2853 (A51691)
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
