Tier 4
   / Tier 4 #1
brain55
Veteran Member
Brentwood, CA
Does anybody know yet what type of diagnostic interface is going to be used. Is it going to be like the early days of automotive computers where every manufacturer has a different plug, or are they gonna be smart enough to come out with a universal interface like OBD II?
I work on a lot of different equipment and at some point soon I'm going to need to find someplace where I can get some schooling on Tier 4 systems.
Brian
   / Tier 4 #2
As far as i Know each manufacturer has their own system, there is no national or international standard regarding off road equipment ??
   / Tier 4 #3
Check with Nexiq which owns Snap-On tools, They do alot of software work with OEM's
   / Tier 4
Thanks, that would be great if they had a solution since I already have a Snap-On Verus scanner.
I'm thinking John Deere will likely incorporate theirs into their existing onboard diagnostics. Not sure what New Holland will do since they seem to use different OEM's. The one that probably interests me most, is Kubota since they are by far the primary OEM that I encounter, followed by Deutz.
   / Tier 4
That's it. All technology and software is proprietary.
I hope they don't do what Bobcat has done and make it so only dealers can plug into their computer. I hope they keep the engine system out of their control module.
   / Tier 4 #7
Regrettably the software/diagnostics, control module, and computer interface come from the Injection System Supplier. In the Kubota/Bobcat/Caterpillar case on Kubota's V3800 engine this starts with Denso. Denso then adds programing and diagnostics to fit that Kubota engine. Kubota then has Denso add programing to fit their OEM customer. While the interface tool used is the sqame tool it has different drivers in it and communicates to different software for each engine. Kubota dealer cannot read or diagnos an engine in Bobcat or CAT and neither of them can read anyother than thier own. This is all setup by Denso.
   / Tier 4
That's not what I want to hear, I just hope they make that software available to the public.
   / Tier 4 #9
I have not read this anywhere but was told that there is an EPA regulation coming in affect sometime in or after 2015 that will require engine manufactures to make their software available. They can (and will) charge for it, and I don't know if there are any stipulations on price.
I do know that Bobcat tried to get Kubota and Denso engineers to get uniform OBD II type software and diagnostics but did not prevail. By end of next year when remaining engines get switched to Electronic Injection a Bobcat dealer will have to have 5 different tools and software to work on the full line of equipment (Kubota, Doosan, Yanmar, Perkins, & Polaris).
   / Tier 4 #10
It's not a matter of what they are going to do. It's already done. Offroad ECU software is proprietary, has been since the first of it was introduced to control transmissions in the early '90's or so. Tier IV doesn't change that. It is clearly moving towards onboard diagnostics, but the information is not in the public domain and isn't likely to move there any time soon.
The primary reason that engine ECU's are kept separate from chassis control units is because the engines may be outsourced, or come from a separate corporate entity.
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
Towable generator (A52377)
Towable generator...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2016 Isuzu NPR 20FT Curtain Side Box Truck (A51692)
2016 Isuzu NPR...
