Tier 4 Owners How Often For Regen?
   / Tier 4 Owners How Often For Regen? #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
For you Kioti tier 4 owners ...... How often does your tractor go into regen? Especially the CK 35/4010 owners. At 29 hrs my went into regen but prior to that my service engine light came on and then wouldn't go into regen when the tractor called for it. Dealer picked it up and it fixed it. I'm at 54 hr and the service engine light is coming back on...... Wondering if it's about to go into regen soon...... Wondering if Its gonna repeat what it did the first time.
Also the tractor at times would start smoking (like a white smoke) for now reason and would last any where from 10 to 30 seconds. After it came back from the dealer it didn't do it for about 8 hours and started doing it here and there. now it does it every time I use it. Last week the dealer sent out a guy to install a kit for the backhoe and gues what? It wouldn't smoke Greer. I started it yesterday to hook up the back hoe and moved it around the driveway and no smoke.... Today I go to plow the driveway and move the tractor 15' and bingo starts smoking for 20-25 seconds...... Then nothing for the remaining 30 mins of plowing....... But durning that time the service engine light came on. Frustrating!!!
   / Tier 4 Owners How Often For Regen? #3
Did dealer say why the engine light was on? Someone had a similar problem with a new kioti, think a CK model and it was a problem with a faulty cam and crank sensors, dealer replace them and last I read all was good.
   / Tier 4 Owners How Often For Regen? #4
My NX6010 has regenerated every 15 hours, I only have 50 hours on it so far. No check engine lights
   / Tier 4 Owners How Often For Regen? #5
My check engine light has never come on. I have 185 hours on it and have done a total of 3 regens, 2 of those was while building a barn with lots of idling time.
   / Tier 4 Owners How Often For Regen? #6
My NX6010 did its first regen at 33 hours.
   / Tier 4 Owners How Often For Regen? #7
I have 160 hours on mine and have had several regens in that time but there are times it may idle for short to moderate lengths of time. No check engine lights thus far.
I forget what exactly but it was a male/female connection wire somewhere that was loose. I called him the other day to let him know what's going on again (service manager)..... waiting to hear back.
Wood Fence Posts (A50121)
Wood Fence Posts...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
Pro Tech 16' Snowbox (A50774)
Pro Tech 16'...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
Unused 2025 CFG MX15RX Mini Excavator (A50322)
Unused 2025 CFG...
