I have a 2012 5055D with 55HP engine and 47HP PTO. I looked up the other day to see if they still offered the 5055D and they do not. They offer a 5055E in 2wd which would be the equivalent. It is rated at 57HP engine and 38HP PTO. I thought how could this PTO drop happen and then I thought of tier 4 which my tractor is not. How could the engine be 57HP with tier 4 and then I found the answer on JD website. "How is engine power measured?
John Deere engineering uses a precise procedure to measure engine-only power levels. The 97/68 EC standard is required in the European Union (EU) as an emission test, so there is some relation to the power a tractor has as a whole functioning unit. However, the procedure requires only that a production engine and radiator are used on a dynamometer test. This 97/68 EC standard is widely used in Europe for various regulations."
I now understand that the Engine is tested without tier 4 in place and the PTO has it in place. Wow a 19.14% decrease in usable power on this replacement for my tractor.
