Tier 4 4520R Filter Cross Reference
   / Tier 4 4520R Filter Cross Reference #1
JonnyRed
North Georgia
5835R Branson
Looking for cross references for engine oil and hydraulic filters.
Engine Oil Filter # EA00001160B
Hydraulic Filter # TA00025525A
I went to O'Reilly's and NAPA and found out the following:
O'Reilly's only came up with an oil filter cross reference: WIX 51334, brought home and it was physically smaller in width and height, I suspect this one is for the tier 3 engine. Mr. Bitz mentions on his site that there was a service bulletin alerting to the differences in the oil filter between tier 3 and 4 engines on the 20 series tractors. Branson Tractor Tech - www.mrbitztractors.com
NAPA only had a cross reference for the hydraulic filter:NAPA Gold 1202, brought home and was about 2" shorter than factory filter, don't know if this will be an issue or not.
Looking for any insight that you guys can offer so I can obtain these filters at the local auto parts houses.
   / Tier 4 4520R Filter Cross Reference #2
I've got a 4720h and apparently none of my filters match yours, but from what I've read about the Hydraulic filter you should stick with OEM because of the flow rate or something. There's several posts on here about it.
I went with Napa on my Oil, Fuel and Air Filters.
Thanks for the input Eric.
I am just going to stick with OEM oil/hydro filters for now.
The aftermarket hasn't caught up to these particular filters yet.
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
T/A Trailer Axles (A51692)
T/A Trailer Axles...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51691)
2001 Dodge Ram...
2003 Acura Tl Sedan (A51694)
2003 Acura Tl...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
