s2dm
- Joined
- Aug 13, 2015
- Messages
- 47
- Location
- Carpinteria
- Tractor
- Toolcat 5600, Deere 210, Cat 320, Kubota KX080, Kubota KX040, CAT CP433 Compactor, Bobtail dump, cushman truckster
Broke a tie rod last week, ordered a replacement, got in the shop to do it and a bit flummoxed. My rig has the flat part on the hydraulic steering shaft on the drivers side which seems to be different than others, but when we got a hold of that and turned the broken side, the steering shaft seems to be unscrewing from the middle, like its two parts. It screws back together just fine and seems rigid after doing so. But I cant get the affected side out, when I crank, the hydraulic shaft just starting unscrewing in the middle.
Few questions:
1) Given the other side has the flat sections, would it be terrible to just put a pipe wrench on the shaft on the broken side as close to the tie rod as possible and separate it that way?
2) It doesnt appear to be, but just wanted to make sure the tie rod wasnt reverse threaded?
3) Is that hydraulic steering shaft two pieces or do I have a bigger problem to sort in there?
Thanks for the input. Despite having a pretty good pile of heavy equipment, the toolcat gets used more than everything else. Pretty indispensable out here. We’ve been sorely missing it the last few days.
Few questions:
