Thursday's dumb questions
   / Thursday's dumb questions #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
I'm going to ask anyway.
#1. Has anyone temporarily used compressed air to actuate hydraulic cylinders?.I am building a project and have to use mock ups for mounting position etc and have yet to pick out a 12 volt power unit.Can I use air to test this or should I wait for my pump.
#2. And this is a good one:eek: Can a pressure washer be converted into a hyd pump using fluid instead of water?.Anybody tried this?.
Now you understand the title.:)
   / Thursday's dumb questions #3
#1-YES
#2-NO WAY
   / Thursday's dumb questions #4
1. YES, but only for testing length&actuating purposes, not for actual usage.
2. NOOOOOOOooooooooo.......!!!!
   / Thursday's dumb questions #5
CAUTION
You probably already know this, but go easy on using air pressure (need to regulate it down). Applying full pressure will/could/might/possibly/probably hurt something, or at least give you a good scare. Folks do this all the time with air (pneumatic cylinders). If it moves too fast, you can put a pilot/screw type valve in the other port (2 way cylinder), and regulate the flow going out to adjust speed. Good luck, tell us more, show us some pics.
   / Thursday's dumb questions #6
1) Yes
2) Never tried, but sounded like one I'd ask. hahaha
Tell us more about your project. You got the whole crew on the edge of our seats now.:)
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
2009 INTERNATIONAL PRO STAR (A52472)
2009 INTERNATIONAL...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
