thumb 47bh
   / thumb 47bh #2
I have the 47 Hoe & have been looking at that unit. If you check "NoBull1" Posts you'll see it on a Kubota Excavator. I'm possibly going to look at his setup this weekend with my tape measure. I'll let you know what I find. My concern is that the dipperstick is 29" to the bump stop & he tells me that the mounting bracket is 18". I'm concerned that I won't have enough room to position it properly for the arm geometry with the limited room. Do a search on "Thumb" & you'll find more information. One fine member on TBN contacted the company and negotiated a $20 discount for TBN members; look at previous posts for the contact e-mail address. Good Luck & BTW welcome to TBN & hope your 4210 is treating you as good as mine.
Eric
   / thumb 47bh #3
This looks like the 'kit' is really that. About 19 parts in a box that all need welding. Just thought I would point that out. My guess is you are looking at about 3 hours of welding time to get it assembled.
I have a thumb on my 48bh. It is one of the best things I ever did to my tractor. It makes the backhoe easily 300% more useful. Mine is a Rankin mechanical thumb. It has a couple of fixed positions.
If you can swing it, I highly recommend getting a hydraulic thumb. I am trying to determine the best way to retrofit mine with a ram. The fixed still works very well, but there are many times I would like to adjust the position of the thumb. Just seems like it would be way more useful.
I like the design of this thumb. Looks like it has good gripping capabilities. I know that the Rankin thumb has been redesigned since I bought mine, and it has a similar look to it.
Kevin
   / thumb 47bh #4
Yes, you are correct; this comes as a kit and when I talked to "NoBull" he told me that everything is precisely lazer cut and fits together great but it's about 4 hours of welding by a pro. I looked at his yesterday & a real nice piece. How about posting some pics of your setup on the 48 Hoe ?? Please, Please. I'll post some measurements when I get the file smaller. Thanks !!
Eric
   / thumb 47bh #5
Kevin,
Can you share any information on where to find out more about the Rankin thumb? Thanks.
   / thumb 47bh #6
Its a little dark for me to take a picture, but here is the companies version:
Rankin Thumb
I bought this when I purchased my tractor. It cost me $600 from the dealer, installed and ready to go.
Welding it on wouldn't be a big problem if you are a decent welder. Otherwise, you should have it done professionally, since you are going to inflict a great deal of pressure on the joints. About a year ago, someone posted a picture of his thumb that wasn't welded on very well.
Check out the picture above. The thing I really like about the kit are the jaws seem to be a better design than the UAT-100 (the model I have). I like mine. The thumb teeth do a great job at digging into trees, but sometimes I wish I had a flatter design when moving rocks. I am sure either would be fine.
Kevin
   / thumb 47bh #7
As promised I'm attaching a pic that I took of the thumb retracted on NoBull1's Kubota Excavator. Hopefully you can make out the measurements I have noted. What we need to do is figure whether or not it will fit so that the geometry will be right. I'm probably gonna take a chance & order one. Hope this helps.
Eric
   / thumb 47bh #8
Thanks for the pictures.
I think you should order one and install it. I really like the thumb design better than mine.
I remember seeing a similar design at the local JD dealer about 4 or 5 months ago. I will call and see who made it.
It would also be really cool if you decided to put a hydraulic ram on it. I may try doing so this winter, but if you wanted to go first, you could tell me how to do it! /forums/images/graemlins/smile.gif
Kevin
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2009 Volkswagen Jetta Passenger Car (A51694)
2009 Volkswagen...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
