throw out bearing replace
   / throw out bearing replace #1
randyswanner
diana,texas
satoh bull
does anyone know the best way to change the troowout bearing on a 184 Cub lowboy
   / throw out bearing replace #2
If it is the wet brass style throwout bearing, pack the center with grease, find a rod out dowel that fits snug in the hole, and drive the dowel in with a hammer. This will cause the grease to displace, pushing the bearing out onto the dowel.
   / throw out bearing replace #3
you have to split the tractor and then the throwout bearing will just pull off. grease will work on pilot bearing
   / throw out bearing replace #4
He's correct... Sorry, major brain fart! I would probably do the pilot while you're in there, if not the whole clutch and have the flywheel machined
CATERPILLAR 325FL EXCAVATOR (A51242)
CATERPILLAR 325FL...
2016 KUBOTA RTV-X900 UTV (A51242)
2016 KUBOTA...
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
71069 (A49346)
71069 (A49346)
2016 Ford Explorer...
