Throttle lever
/ Throttle lever #1
roadtrash
N. Mich
kubota
I've got a 3010 with a minor problem, the throttle lever works fine to about 2000 RPM, when I want to increase the RPM the lever becomes extremely hard to pull down, is there any adjustments I can make to loosen it up a little. I would appreciate any info. Thanks
/ Throttle lever #2
Yes, it's adjustable. There's a simple friction-binding bolt adjustment near the floorpan that you just back off a fraction of a turn. However, it's on the inside of the cover underneath the steering wheel/instrument cluster, so you have to open it up to reach it. 30 seconds to adjust, but 15 minutes disassembly first!
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2015 John Deere 3046R Compact Utility Tractor (A63116)
2015 John Deere...
429888 (A61165)
429888 (A61165)
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A63118)
2025 Wacker Neuson...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
