Throttle Lever stiff
   / Throttle Lever stiff #1
theboman
Veteran Member
Grayson, KY
Kubota B7500 HST
My throttle lever ispretty stiff. Whats the best way to lube it to free it up. You really gotta bump it to move it.
FYI, B7500 and it stays indoors, uinless I'm using it : )
   / Throttle Lever stiff #2
This is pretty common. Kubmech gives a good explanation of how to adjust this on a B2100 <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=owning&Number=63965&page=&view=&sb=&o=&vc=1>here</A>. Probably not much difference with our B7500's. I'm going to wait a little longer to see if it gets easier.
   / Throttle Lever stiff #3
had the same problem with my 7500. there are 2 nuts at the bottom of the trottle lever. they apply the tension to it. all that you have to do is loosten them and then retension them to your liking.
   / Throttle Lever stiff #4
Same process but easier with my b21tlb - after adjusting it was either too loose or too tight Kubota needs a better setup here to lock the nuts.. Decided to leave it as it was, tight.
Carl
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2006 FAE Mulcher (A49461)
2006 FAE Mulcher...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
