Throttle lever sticking?
   / Throttle lever sticking? #1
Agentiron
Northwest Indiana
I have a ck20 that I dearly love, but have had my throttle lever sticking of late. It does not throttle down right away when you move the throttle back. It will ususally do so, but may take several seconds. When throttling up, it does not always increase rpm's as you would expect it to, but may jump up all of a sudden. Is this common? Can it be addressed with lubrication?
   / Throttle lever sticking? #2
my dk35 was doing the same thing , sprayed wd 40 on linkage under hood works great now . good luck, jim
headacres
Worked like a charm, thanks for the suggestion. If ever I find a problem, or perceived problem with the tractor I just need to run out and hose it with penatrateing oil. So far it has fixed everything from my stiff four wheel drive lever, to my sticky hst peddle and everything between.
1 Oliver Front Weight (A50515)
1 Oliver Front...
John Deere 643 Corn Head (A50514)
John Deere 643...
UNUSED AGT ATK-B1000 CARLIFT (A51244)
UNUSED AGT...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
UNUSED TOPCAT SSSG72 HYD QUICK ATTACH GRADER BLADE (A51244)
UNUSED TOPCAT...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
