Throttle Lever Friction Disk Failure on '21 3620H ROPS
   / Throttle Lever Friction Disk Failure on '21 3620H ROPS #1
bcs001
Dahlonega, Ga
2021 Branson 3620H
315 hours on my 3620H ROPS today and I noticed during the day a reduction in hand throttle lever friction then at some point it went completely away and there was about a 40% piece of plastic washer on the floorboard just under the throttle lever which I'm assuming is the friction disk. I looked thru the service manual that was posted here by Asteral and I didn't find any parts diagram for this lever assembly.
Can someone explain what the procedure for replacement is? Based on the piece I found, I should be able to make something equivalent in size and thickness to get me by until a replacement part can be obtained. Are there any special tricks I need to know about when opening up the dash panels and replacing the friction disk.
Thanks.
   / Throttle Lever Friction Disk Failure on '21 3620H ROPS #2
If like my 2400H it is just sandwiched between a couple of steel washers and has a wave washer for setting tension or friction. On mine hardest part is getting my fat fingers in the area where the washer goes.
Got it fixed with a large washer I made from an old 5 gallon paint can lid then sandwiched it between 2 fender washers. Will have to see how it holds up in the heat.
Access was easy with removal of instrument cluster and right side dash panel.
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
SET OF (2) TITAN HI-TRACTION TRACTOR TIRES/WHEELS (A51244)
SET OF (2) TITAN...
Ford Disc, 2-piece Cone Bearings INOPERABLE/PARTS ONLY (A52128)
Ford Disc, 2-piece...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
