Throttle control
   / Throttle control #1
LASTWEST
CASE 9030B
Has anyone had trouble with a Case trackhoe relating to the throttle control motor and/or the throttle potentiometer(throttle control )?
There is no response on the throttle knob--I have replaced the control motor and the throttle control potentiometer in the cab and still no luck. Fuses have been checked. The machine is a 1997 9030 B and has a computer. Thanks for any help.:confused:
   / Throttle control #2
Does the Case have the auto-idle on the right control lever..?? A push button deal on the end of the handle. Back in '98, I ran several different excavators during the cleanup of the big flood in Eastern Ohio... One being a new Case 9030. Can't remember if it was Case that had this feature, or John Deere.
   / Throttle control
Yes there is an idle button on the left hand control stick as I recall,that seems to be a reasonable assumption for a fault. Monday, I hope to talk to a serviceman to see where he directs me. I will keep you posted as to any encouraging finds, Thanks
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
2013 Mack GU813 Roll Off Truck, VIN # 1M2AX13C1DM019680 (A51572)
2013 Mack GU813...
