Throttle backing down
   / Throttle backing down #1
AUSTENNN10
Alto nm
Ls 3033
I have a 3033H and when I make a run to the slash pile I set the throttle at almost full at 2,600 rpm. As I go up the driveway the throttle lever slowly works its way back and I end up at 1,900 rpms after 20 seconds or so. I then press the throttle forward again. 200 hours so I suspect something needs adjusting.. Anyone know what?
   / Throttle backing down #2
Follow the linkage from the sterring wheel thru the dash frame.. somewhere in there, there should be some "fiber disks" that hold tension between the rod & the tin.. they are probably loose or rotted.. just make some.. Good luck..
   / Throttle backing down #3
I've seen this before. Many of these throttle controls have nut in the center of the lever that you can tighten to snug things up. The trick is getting to it. You may have to remove a bezel, pop a switch etc to get to it.
   / Throttle backing down #4
What they said.....
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
KOMATSU WA250-3MC WHEEL LOADER (A51242)
KOMATSU WA250-3MC...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
7' ROTARY MOWER (A51243)
7' ROTARY MOWER...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
