Threw together a stump grinder
   / Threw together a stump grinder #1
jwmorris
Veteran Member
Converted a rope pull 8hp Briggs over to electric start, used the handle off an old rototiller, cutter off of a horizontal mill, front tires of a dead riding mower and some other stuff to make a stump grinder.
The tounge is held on/removes with a single lynch pin.
   / Threw together a stump grinder #2
Looks basically like my Vermeer except the business end isn't quite as long. The only problem that would really cause is that it the machine would be angled diwn in the hole more. The handles will get higher too.
Make sure you have a brake for one of those wheels so you have something to pivot the machine on when you cut.
   / Threw together a stump grinder #3
Looks very practical and cost effective. Looking forward to hearing how it works out.
   / Threw together a stump grinder #4
How does it drive??? The garden tractor transmission???
   / Threw together a stump grinder #5
with my build the hardest part was the cutting wheel. Did you buy yours or make it? I have seen a guy on Ebay seling premade wheels
The brake is on the left wheel, operated by the lever on the left side, it over center locks the wheel when you have it where you want it. The only drive is on the horizontal mill cutter and that is just a belt. The idea is to push it over the stump, lock the one wheel and pivot it side to side around the one wheel (like a bunch of others work).
The cutter does have a 2" diameter hole with a 1/2" key way so I did have to machine and broach an adapter for it to fit on a 1" shaft with 1/4" key way.
Brake is on right in this photo.
   / Threw together a stump grinder #7
So you pull it close with a tractor then push it by hand and then lock the brakes. Neat, simple, and easy
Yes, the hitch is only to move it from one location to another, so I don't have to load it onto something to move it around the property.
   / Threw together a stump grinder #9
I really like it. Though i don't need one. Simple easy and could tow with anything really
   / Threw together a stump grinder #10
Very nice. I have a number of small to med stumps that need grinding if you need a demo site...:)
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Unused 2025 MS380 Mini Track Loader Skid Steer (A51691)
Unused 2025 MS380...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
