Three ring binders for shop manuals
   / Three ring binders for shop manuals #1
Captain Dirty
Platinum Member
Eastern Mass
Goldoni 600, Kubota L45
Just received the workshop manual for my tractor, a 1.5" high stack of looseleaf sheets. What binders do you recommend?
I remember relatively thick (3/16"?) pasteboard front and back covers wrapped in canvas from Viet-Nam-era service. Some even had metal hinges! If used in the field the covers would soil easily, but they were relatively durable. Usually the failure was mis-alignment of the rings. Apparently canvas has gone the way of the dodo to be replaced by plastic over thinner pasteboard. Office Depot, Staples, et al offer a range of prices, and presumably the more expensive are "better", but I would hesitate to say any are "good"; the plastic that serves as hinges tears, and the rings still mis-align, although the slant "D" rings are an improvement. Buyers' guides and reviews seem oriented toward sales presentations, not field or even shop use.
I have photocopied the few pages of an often-used procedure such as disconnecting or reconnecting the backhoe, put them in document protectors and then 1/2" all-plastic binders (can't find any brand markings on the binders; Acco?). The plastic is relatively robust and wipes clean, but the 1/2" size is too small even for the operator's manual.
There seem to be two choices--buy cheap with the aggravation of replacing often, OR buy dear with the hope of replacing less frequently. Are there robust binders out there?
Captain Dirty
   / Three ring binders for shop manuals #2
I use old binders from where I worked. We went through a LOT of training courses and about every course handed out reference materials in big binders. Often the type of binders with a plastic "pouch" on the front in which they slid the cover of the course/title of the training. Most every decent sized operation generates lot's of binders being thrown out, ask friends.
For the "special" stuff I place it in a ziploc bag, run duct tape across the "bottom" edge, punch 3 holes in it and put it in the binder.
   / Three ring binders for shop manuals #3
I use Avery HD with "slant" D rings. The ring assembly mounts on the rear cover, instead of the middle/end cover. This makes it easier to lay it open and flip through the pages. It lays flat when open. You can buy in different thicknesses. 1" to 4" thick. A 1 1/2" holds about 400 pages.
I also buy them in green for my JD manuals.
1998 Caterpillar TH63 6,000LB 4x4 Rough Terrain Telehandler (A49346)
1998 Caterpillar...
19010 (A48082)
19010 (A48082)
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
2017 Bad Boy Outlaw XP 61in Zero Turn Commercial Mower (A49346)
2017 Bad Boy...
2002 International 4400 SBA 4x2 (A49461)
2002 International...
2016 Ford F-550 Crew Cab Mason Dump Truck (A48081)
2016 Ford F-550...
