Three Point Plow (Chisel plow)
   / Three Point Plow (Chisel plow) #1
llewellynsd
Western Maryland
Sath S-370
I have an old walk behind (horse draw) plow that I would like to somehow convert to hook up to my 3 pt. hitch. Has anyone been able to do this? I have ripper teeth on a bar and also a set of discs that I pull behind my little 4WD diesel but I like the way a plow turns the dirt over and breaks up the sod.
Has anyone tried modifying one of these old plows? If some could you all post some pictures.
Thanks.
   / Three Point Plow (Chisel plow) #2
Confused a bit by the "chisel plow" in the title of this thread and then talking about a horse drawn plow that will turn the dirt over. Seems you are talking about a moldboard plow.
If so, it probably can be done, if you build into the design enough adjustable parts to get it to plow right. That could be tricky if you don't understand how a moldboard plow pulls.
Forget this if indeed you have a horse drawn chisel plow. I pic would be very helpful.
   / Three Point Plow (Chisel plow) #3
It can be done. I know of a party who deals in used/old farm eqpt that reconditions a lot of gems from farm auctions. Buys old pull-type plows and has his machinist/welder buddy take them apart and fabricate a one-bottom 3-point plow from each beam/share/moldboard section. Sells to people with small tractors for garden plowing.
BUT
A horse drawn walk-behind may be worth something on the antique market. Maybe you could get enough to buy a plow. Check it out.
Cheers.
   / Three Point Plow (Chisel plow) #4
Fredex
You are right on with the suggestion. One on eBay now with a "buy now" price of $2000, and a starting price of $500.
eBay horse drawn plow
Not a chisle plow tho. There is also a horsedrawn potato plow listed as well. These Iowa farmers are selling out. /forums/images/graemlins/grin.gif
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2016 JOHN DEERE 8245R LOT NUMBER 180 (A53084)
2016 JOHN DEERE...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
378667 (A51573)
378667 (A51573)
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
