Hello all,
I've done some research on this, but haven't been able to find very many answers. I have an '07 Deere 3720 with a FEL and power beyond (for the backhoe, no other hydraulics beyond normal tractor stuff). The backhoe is detached, so the power beyond is return-looped. Today, when using the 6' landscape rake to clear up some brush, the TPH started pulsating. Here's what I've noted:
When the implement is full down (ground contact), there is no pulsing.
When there is no implement on the TPH, there is no pulsing.
There is no effect on the FEL or any other system (steering, etc.).
The pulse is approximately 2 Hz at full lift.
There are no leaks under the tractor.
The lower the implement is to the ground, the slower the pulse rate.
The TPH maintains the implement at approximately the height commanded, even when pulsing (~1/2" drop between pulses).
Tractor does not require any power above idle to lift implements.
TPH drops quickly (full lift to ground contact in ~4 seconds) when tractor is shut off (this never happened before).
Hydraulic fluid is correct type, about two months old and correctly filled.
The TPH works normally except for the pulsing.
I have to assume there's an issue within the system, such as a valve or seal but not sure where to start. Any advice out there?
Thanks,
Ed
Thanks,
Ed
