THREE CYL INJECTORS
   / THREE CYL INJECTORS #1
artnadam
new cumberland, pa
suburban
I have a 1990 +/- L2050 with 660 hrs ---starts a little hard, more white smoke then I am use to on other diesels. A friend thought after 26 years and not a lot of hrs, injectors should be pulled, overhauled and calibrated.
Any thoughts on symptoms as described and a recommended fix?? Thanks
   / THREE CYL INJECTORS #2
Before going through the trouble of removing the injectors, I'd check the glow plugs and their power supply to make certain they are functioning as designed. This assumes the tractor has glow plugs in the first place.
My neighbor's B9200 started more difficult than it should. Fixing the old wiring to the glow plug circuit and replacing 2 GP's resulted in much easier starting.
Thanks, MOSHIP! Yes, mine has glow plugs, I'll check them and the wiring. Thanks again
   / THREE CYL INJECTORS #4
I agree with moship. Bad glow plugs will also cause white smoke on start up due to the fuel not burning completely. You can check them with a ohm meter but they have to be separated and the engine cold. If they are just a little warm you will lose resistance.
I have seen them on ebay for under $50.00 for a set of 3, personally I would just change them.
Also as stated make sure you are getting proper voltage when you hold it in the glow position.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2025 CFG Industrial QH12R (A50123)
2025 CFG...
2007 Ford Escape XLT SUV (A51694)
2007 Ford Escape...
(INOP) YAMAHA MOTO 4 ATV (A51247)
(INOP) YAMAHA MOTO...
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
2019 FORD TRANSIT 350HD VAN (A53426)
2019 FORD TRANSIT...
