Thoughts on a warm weather visit to another dealer
   / Thoughts on a warm weather visit to another dealer #1
daTeacha
Veteran Member
Funk, Ohio
Well, it wasn't in the single digits today, but I did have the day off work. I had to go into town for errands and decided to make the run up to the Deere store.
I looked closely at a 2305. I have to rule it out because there is very little ground clearance for running around in the woods and also because the hydraulic connectors and flex lines are hanging very low on the right side of the tractor. In my use, I think those lines and connectors would last about an hour. Just today, I got a good size stick caught up between the loader bucket and the front axle of the 'bota.
I drove a 3120 with the E-hydro transmission. Aside from the fact that the tractor is considerably taller than my strict 84" ROPS up height limit, it too had soft hydraulic lines on the underside. These were just behind the front axle and more or less waiting to get snagged and torn. I really don't want a line under pressure being torn open.
I drove a 4110. This model is on the way out, but it might work. It was pretty easy to drive around, turned pretty tightly, a bit more so when I used the turning brake. Turning sharply in 4wd required a noticeable increase in pressure on the hydro pedal. The brake made it worse, necessitating that I push harder on the go pedal than on the brake.
On both tractors, I was impressed with the speed of the loader operation. It was a little disconcerting to hear the bucket banging around on the quick hitch when I "dumped" the bucket, but I guess it isn't going to fall off there. The 4110 is close to my height maximum. I need to check the catalog to be sure. It was kind of odd to have the top half of the ROPS leaning forward when it was locked in place. I thought they were all straight. Taking the loader off the machine was very neat to watch. It took about a minute for a guy who knew what he was doing to set the loader on the ground, leaving only the lines to disconnect. Putting it back on was equally quick. I don't know how often I might need to drop the loader, but it sure is slick. There is also a float position on the loader, which isn't mentioned in the brochure but would be very handy when smoothing a driveway or some similar job. For the uninitiated, this means the bucket is just hanging off the tractor with no pressure in the arms that lift or lower it. You can set an angle which it will hold, then it just works by gravity, which can give nicer results than down pressure, especially when backing and using the loader to smooth over rough spots.
After spending the early afternoon working around the barn/shop, I was on the Kubota moving some dirt to a new winter door for the sheep and donkey. I was particularly aware of the shifting needed to load the bucket, move the load, climb the hill, and dump the bucket. I was also acutely aware of the sidehill coated with slimy manure that tended to make the 'bota crabwalk toward its destination.
I called the Agco store after I got inside, asking about the ST34a, which the catalog shows has a height of just 81" with the ROPS up. Problem is the same chart shows a turning radius of 98 feet which I suspect may be a typo. /forums/images/graemlins/laugh.gif The guy I talked with said they don't sell a lot of hydros in that size, with most buyers going with one of the two available synchro manual boxes, both with 4 speeds and a shuttle shift feature. The 8 + 8 requires clutching then shifting the direction lever. You go backwards in the same gear you were going forwards in. The 12 + 12 has a power shuttle, meaning no clutching is required to change directions, just move the lever. The 8 speed has two ranges on a 4 speed box, while the 12 speed has 3. You need to stop to change ranges, but within a range, you can shift from 1 to 2 to 3 to 4, just like a car. They have an 8 + 8 sitting on the lot and he invited me to come over and run around on it a while, so I may have to drive over there to check it out if I get time.
   / Thoughts on a warm weather visit to another dealer #2
Don't forget, that 790 and 990 Deere's will soon have HST trannies in em.
/forums/images/graemlins/grin.gif
   / Thoughts on a warm weather visit to another dealer #3
<font color="blue"> Turning sharply in 4wd required a noticeable increase in pressure on the hydro pedal. The brake made it worse, necessitating that I push harder on the go pedal than on the brake. </font>
Is it a good idea to turn that sharply while in 4WD? Just asking, I know my NH does not like a sharp turn in 4WD.
Most of them don't like it, hydro or gear, especially on a solid surface. It puts a lot of stress on the front axle and tires. I was on gravel today, but still got some lurching as I turned hard. I do some close quarters maneuvering in a barn and barnyard, often in slimy manure/mud/slush. You just don't know the meaning of fun 'til you find yourself sliding around in the stuff with a full bucket of manure trying to avoid the electric fence and trees in the barnyard. Having the ability to use 4wd while working in close quarters is important to me, along with a couple of other peculiarities like being less than 84 inches high and not having anything that could be torn, ripped loose, bent, or otherwise broken hanging unprotected on the bottom of the tractor.. The closest my tractor comes to normal use is brush hogging puckerbushes and other unpleasant forms of vegetation.
   / Thoughts on a warm weather visit to another dealer #5
Slopping around in the mud and muck might be okay....... /forums/images/graemlins/grin.gif
   / Thoughts on a warm weather visit to another dealer #6
I have a MF 1260 with the four speed gearbox, four speed range and the manual shuttle shift. I don't like it for loader applications involving heavy material. In order to reduce the speed and limit spinning, I need to drop either the range or gear, fill my bucket and then in addition to the shuttle, if I want some speed, I need to change gears, etc. To much to do!
My loader is quck detach. The only application is for service or perhaps to use a belly mower. Without the loader, the front end is to light for rear mounted applications.
Why the 84" limit? Garage or trailer door?
Garage, firewood storage and sheep shed are all limiting the height. I get wood from the shed, haul it down into the garage to fill the bin that feeds into the living room. The sheep area needs to be cleaned out a couple of times a year, and it's just a much nicer job with the loader than a pitchfork. /forums/images/graemlins/grin.gif
   / Thoughts on a warm weather visit to another dealer #8
</font><font color="blue" class="small">( Garage, firewood storage and sheep shed are all limiting the height. I get wood from the shed, haul it down into the garage to fill the bin that feeds into the living room. The sheep area needs to be cleaned out a couple of times a year, and it's just a much nicer job with the loader than a pitchfork. /forums/images/graemlins/grin.gif )</font>I understand that. Within reason (ducking height), you can fold down the rops for the occasional low ceiling.
Yeah, I know that, but the sheep shed is the main problem. I use the loader to clean the used hay out, and coming out of the door I immediately encounter a sidehill. It had to be that way when I was building the thing for a couple of reasons. My whole property is on a slope ranging from about 3/12 to 4/12 with some parts steeper. The manure gets slippery, and the downhill leads to a couple of big trees and the fence, not to mention the remote possibility of tipping. Hopefully a tractor bigger than my little B7100 won't seem quite so nervous working there.
   / Thoughts on a warm weather visit to another dealer #10
I think one of my first new tractor projects would be trying to do something about the incline right outside my sheep shed. Can you?
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
New Holland 477 Swather/Mower Conditioner (A52748)
New Holland 477...
2011 NORMAN POWER SYSTEMS 100KW GENERATOR (A52472)
2011 NORMAN POWER...
2008 Volkswagen Passat Passenger Car (A51694)
2008 Volkswagen...
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
