Third time my tractor nearly killed me
   / Third time my tractor nearly killed me #1
Jkline
I have a 2004 JD 4120 with 300 hours on it. Original owner. My ground is very steep, where you can only go up/down. I was brushhogging my field and I just started going down the crest of my hill and my transmission popped out of 'B' gear into neutral-- I was in 2wd. Even with the rear wheels locked up, the tractor picked up speed and was going over 20mph by the time I reached the bottom of the hill. How I didn't flip... no idea.
Anyway, this has happened two other times over the last 13 years resulting in real pants-filling experiences. I forgot my rule: always gear 'A' and 4wd, as it has never happened.
I really need to get this fixed, if there is something to fixed, as I dare not let my kids use it. Any suggestions?
Thanks,
   / Third time my tractor nearly killed me #2
You have been lucky;get it fixed and follow your own advise.
   / Third time my tractor nearly killed me #3
Very scary situation. Take it to the dealer and see what they say.
Don't want to read about you in the obituaries!
   / Third time my tractor nearly killed me #4
Glad you rode it out without serious injury ... or worse. I would suggest sparing no time or cost to get that fixed.
   / Third time my tractor nearly killed me #5
If you reached 20 mph with the bakes locked, possibly that is a hill that does not need to be mowed.
   / Third time my tractor nearly killed me #6
I mow on hillsides quite a bit. After sliding about 150 feet down the hill on clover in July last year, I only mow in 4wd now. Popping out of gear is unacceptable in these situations, better fix it before it's too late.
   / Third time my tractor nearly killed me #7
The third time? I'd opt for different equipment, or leave it to mother nature.
Sooner or later, bad stuff will catch up to you. A roll over is not something to be taken lightly. You hit a dip at 20mph with that speed and weight, you can easily roll over. Rear wheels leave contact with the ground, no brakes for you.
   / Third time my tractor nearly killed me #8
   / Third time my tractor nearly killed me #9
I know that everyone's circumstances are different, but I for one am a believer in only taking my tractors out of 4x4 when need be, such as on a paved road. Other than that I leave my machines in 4x4 mode. I would rather accept the minimal addition wear and tear than be caught in 2wd with a problem. I would bet that my 75hp tractor hasn't been out of 4x4 mode 10 times in the last 12 years.
   / Third time my tractor nearly killed me #10
Dang,glad your still w/us.
As other said get it fix,what type tire thread?
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
UNUSED FUTURE FT-SB45 SILENT BREAKER HAMMER (A51248)
UNUSED FUTURE...
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
