Third SCV
   / Third SCV #1
JD3520
TEXAS
JD 3520
I did not get the third SCV when I bought my 3520 and now want/need one.
Is this something I can add on or is it better to let the dealer install it? The picture in JD parts shows a kit but that is only a lever, pins, pipe couplings, and hoses with female connectors. It doesn't show where to connect the lever. Is the control valve already on my tractor or is that a separate purchase?
Any info would be helpful.
chuck
   / Third SCV #2
Your tractor already has the "valve", the kit is just the lines and lever as you already guessed, if you have a moderated level of mechanical ability then you should do it yourself IMHO /forums/images/graemlins/grin.gif
   / Third SCV #3
I added the 3rd SCV to my 3320 a couple of months ago. I consider myself mechanically inclined and all that, I always do my own car repairs. But I found it to be a major PITA that I probably wouldn't do again. The instructions are real basic, so if you don't have a service manual (I don't) you'll have to figure out the "hows" on your own. Removing the one piece plastic cover under the seat was a real treat. You have to remove all the lever handles and then wrestle the thing off. Feels a lot like removing the dashboard on a car. But the part that almost drove me over the edge was figuring out how to weave the hydraulic lines through through all the other hydraulic lines, to the valve. Remember the Rubic's cube?? I tried dozens of sequences before I got the things in. I found that these compact tractors are more like working on a car than a tractor...everything is tight! Took me several hours of aggravation. But hey, I saved a few bucks. Anyone else find this to be tricky or is it just me?
   / Third SCV
Brian,
how much does the kit cost? I was told by others it is around $200.00 but i have not checked with my dealer yet.
chuck
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
OLIVER DAHLMAN LOT NUMBER 248 (A53084)
OLIVER DAHLMAN LOT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
