Hombre
I have a couple other threads here in the last couple weeks as to my installing a third function kit on my 4020R Branson. I'm starting this new one because of an issue with fittings (perhaps not all Branson's have but there are many for sure) on the tractor and my "quest" to resolve the issue. The fitting is the one where you go from the power beyond port on the tractor valve. PTSG was correct in my earlier thread that it IS BSSP, the only ones I have found on the tractor by the way, and are on each end of this hose. The problem is/was that to make a "jumper" hose from the hose from that fitting to your new valve would take a Male end to that hose and then whatever you needed on the other end to hook to the new valve. Follow me so far? Well, I went to three different hydraulic shops with fitting in hand, schematic drawing in hand, and spent a couple hrs with a couple of them (they're friends of mine who have been in the business for many years) going through book after book looking for a way to hook all this together WITHOUT REMOVING THE ENTIRE HOSE FROM THE TRACTOR, couldn't find the needed fitting (just one of them) the old story of, sorry you can't get there from here thing......I was resigned to the fact that I was going to have to remove the hose in it's entirety just to replace the "offending" fitting on the end to something I could work with (JIC, pipe, whatever) when I had an epiphany, call someone who does this for a living (or for customers anyway). I contacted our own Dave's Tractors in Red Bluff and talked to Jared. When I started to tell him of my third function valve woes he knew where I was going almost before I got started. Told me they had what I needed, went out of his way and sent me an e-mail with pictures AND instructions on which went where. (I did not buy my tractor there)This is a BIG THANK YOU FOR JARED AND DAVES TRACTORS.....this is a bit of a more personal consideration, Jared told me what fitting's would work and where they purchased them. I COULD have gone on line and purchased direct instead of from Dave's and saved a few bucks, but with the service I received from Jared, there was no way I was going to do that, I figure his experience and knowledge and willingness to help is worth something even the little bit it cost me. Thanks Dave, you have a good team. I'm impressed.
