Third function quick connect
   / Third function quick connect #1
svendawg
Salem, AR
Mahindra 4550 & Mahindra 5155
One of the quick connects on the third function to the rear of my 4550 Mahindra is leaking. Usually a small puddle overnight. In this something that I can replace the seals/o-ring or do I need to buy a new quick connect. If it can be repaired is there aource for where I can buy these seals of o-rings
   / Third function quick connect #2
Not a repair item. But they are a stock item at most places that have hydraulic parts (assuming it has common threads)- some auto parts stores, truck shops etc. Pull it and the other end (typically make) off an implement so the shop can match it up.
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
