Third Function Kit for 2014 Boomer 33
   / Third Function Kit for 2014 Boomer 33 #1
NBABUCKS1
New Holland Boomer 33
New tractor owner and I'm not sure what I'm going but I'd like to get a grapple to help clear some wooded land. I know I need a third function in order to operate the grapple. Is there a recommended third function valve that works best with the Boomer 33? I've seen one from Summit Hydraulics and also Everything Attachments. Anything else I should know about or other people have tried this?
Thanks!
   / Third Function Kit for 2014 Boomer 33 #2
You can run a grapple or hydraulic snow plow off your rear remotes if your tractor has them (usually green and blue caps if you have 2 sets). Measure with rope or an old garden hose how long hoses you'll need. Run them from the back under the tractor along the frame to the FEL cross tube. Can get hoses and fittings from tractor supply or dealer. Not quite as nice as a third function, but a lot cheaper and works well for most.
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
Bill 528 Grain Cart (A50774)
Bill 528 Grain...
Massey Fergusson 4253 (A50120)
Massey Fergusson...
Kioti LK2554 Tractor (AS IS) (A50774)
Kioti LK2554...
