Third function for loader
   / Third function for loader #1
cj7m57
VT
Ford 1910 (1983)
Am thinking of getting a thumb-type grapple for my loader bucket, and am trying to figure how to hook up the grapple cylinder. I have a ford 1910 with a 770b loader, and no remotes. The 1910 has an auxiliary hydraulic port, which is intended to supply hydraulic flow for a backhoe, etc, when the position control lever is put into a slot at the top of its range.
This setup works ok to supply a woodsplitter now, so I am thinking I could use this port, run through the appropriate open center DA valve (like item 9-7861 at the surplus center website), to run a thumb. I know little about hydraulics, so wanted to see what people think.
The only disadvantage is see is that I would need to have the three point raised whenever using the thumb, but I would be using a concrete counterweight when using the thumb in any case, so probably not a problem.
Does anyone see any issues with doing it this way, or a better way that doesn't cost a lot more?
   / Third function for loader #2
When you are using the BH hyd supply, do you have use of the 3pt?
If you need 3pt and are using the BH hyd supply, then the grapple valve has to have a PB outlet.
The PB from the grapple valve will feed the 3pt, and all tank limes go to tank. Then you will have use of all valves.
9-7861 http://www.surpluscenter.com/_MoreSpecs/iPrinceMBValves.pdf
INSTALL THE HIGH
PRESSURE CARRY OVER PLUG
(1/4-18 BSPT) INTO THE
INTERNAL THREADS TO THE
INSIDE OF THE "C" PORT.
The aux port is kind of different- it only has flow when the position control lever is all the way up. You put the lever in a slot over the highest setting, and the 3 point lift arms go to full height and stay there, and only then there is flow through the port.
So the 3 point must be part of the circuit somehow, because the lift arms stay up even under load while the aux port is in use (which was not great when using the 3 point splitter). I suppose having power beyond might be good for future use in any case, even if it would cost a bit more now.
   / Third function for loader #4
It seems that plumbing an electro-hydraulic '3rd function' onto the loader valve (a diverter, more or less) is what my grapple builder recommends. Using a finger-tip button/sw added to the stick, the curl spool controls the 3rd function to operate the lid (or other remote accessory) up or down when engaged. Either cylinder(s) remains locked when using the other 'function'.
I plan to start or embellish a thread when I get the whole thing put together and working. There is no need for, or confusion with, PB's intended use/operation and I'll let y'uns know somewhere if it all goes as easily as it sounds.
   / Third function for loader #6
I agree with JJ. I'd go with a diverter setup. You'll like it just fine and it won't have any affect on the other functions at the rear of your tractor.
   / Third function for loader #7
Tony at MI&E showed me a 6-port, spring return, single solenoid valve, somewhat like EA's shown here, to add the 3rd function:
Add 3rd function to your tractor
(Click to see larger image)
Of course one line is teed to both curl cylinders and there will be only one cyl for the lid. P-1 & P-2 connect to the existing lines from the curl spool.
   / Third function for loader #8
Yep, that's your average Diverter Valve.
   / Third function for loader #10
JJ, can you point me in the direction or where that valve can be purchased for $150. I had never seen them below the $160 that SC use to sell them at and my guess is that there is now no surplus, so that is probably why SC does not have them any longer. :(
I never saw that valve at Baileys, they have a cheap imitation that I have seen for $110.
The Hydraulic store has them, but they are over $200. :eek:
There are lots of other valves out there, none quite as clean as the Bosch unit IMO. ;)
Just my :2cents:
2000 JOHN DEERE 444H WHEEL LOADER (A52705)
2000 JOHN DEERE...
Forklift Safety Basket Attachment (A55787)
Forklift Safety...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2023 KAUFMAN MINI V CAR HAULER TRAILER (A54607)
2023 KAUFMAN MINI...
