Thinking of a X739 what other brand's models compare?
   / Thinking of a X739 what other brand's models compare? #1
jpmurf
satoh
Thinking of a X739 what other brand's models compare? I really like the aws function, and I need awd .
Looking at this one but its 6years old, although it only has 64 hrs .It has a hardly used 54" auto connect deck, but not aws
   / Thinking of a X739 what other brand's models compare? #2
There is not much that compares to the x7** garden tractors. Neighbor has a x700, I have a x744 diesel AWS, and dad has a x749 diesel AWS AWD. We all have the 60" decks and dad plows snow with his.
thanks for the response, I heard they discontinued the 749 because it was too heavy and because of that it needed a roll over bar.
   / Thinking of a X739 what other brand's models compare? #4
I found a used x749 for my dad that had low hours and was set up like he wanted it. I also found my x744 used with low hours. The "old" diesel is something like 80lbs heavier than the new one. We have not had any issues yet with them.
Anybody have experience with the different cabs? Floppy or hard? Heat?
not mine just thinking about it......
I found a 2018 X738 with lots of bells and whistles except the aws for $14500.Might be able to whittle them down somewhat . Can I get by without the all wheel steer? Sure would be great mowing I would think
   / Thinking of a X739 what other brand's models compare? #8
Hard to beat the x7-series as a full function garden tractor. Large, powerful, capable, 3-pt hitch option, rear/mid/front PTO options, AWD, AWS. Couple of things to keep in mind as you look:
Somewhere in the prior 'generation' of x7-series (back when the models were x72x (gas) and x74x (diesel) they changed from mechanical four-wheel drive to hydraulic AWD which continues with the current x73x and x75x generation. The hydraulic AWD is very highly regarded as a system that just plain works well. Being full time with no need to turn it on or off and designed so it transparently assists as needed I highly recommend getting a tractor with this on it. It has essentially zero negatives, beyond initial costs and a bit more maintenance but I find it invaluable.
Seriously consider whether you need AWS. The non-AWS models already have a pretty tight turning circle and can mow pretty closely around trees, etc., especially with the 60" deck. Avoiding it will open you up to a lot more models, availability and price points, especially in the used market. And there are fewer moving parts to potentially cause issues.
Both diesel and gas models are very capable. Diesel tends to hold value a bit better, but has a higher initial cost. It does use less fuel though (0.8-0.9 gal/hr at WOT versus 1.2-1.3 gal/hr for gas). Not really a big cost factor, but for me I can mow my entire 7 acres on one tank of diesel but I'd have to stop and refill if I had a gas engine and that is meaningful to me.
The earlier generation can use a factory loader and is more compatible with the 7-iron decks, if that matters to you. The current generation can use an aftermarket loader and may be able to use a 7-iron deck but with restrictions (lift height reduced, not direct fit, deck warranty voided).
Yes, the current generation of x7 doesn't have a diesel AWD AWS model like the x749 because the weight would have caused it to require a ROPS.
Rob
   / Thinking of a X739 what other brand's models compare? #9
I would not go without the AWS.. shines on many occasions and can't think of any negatives.. had them on my lawn/garden Deere tractors for 25 years.. no breakdowns, many hours.
A real benefit when mowing sidehills, when stuck in a tight spot, when turning at corners, around, or around trees.
bought the X738 just too many extras to pass up(there is more than the photo), hope I don't miss the AWS.
7021 (A50322)
7021 (A50322)
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2005 Wells Cargo CEW202 20ft T/A Enclosed Concession Trailer (A51694)
2005 Wells Cargo...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2015 FREIGHTLINER...
