THinking of a new 2025R... Need some inputs
   / THinking of a new 2025R... Need some inputs #1
megaboz
Platinum Member
Fairmont, WV
'17 2032r (soon)
I haven't been on this site in a long time...
I am thinking of trading in my 2520 for a 2025R.
What are any issues, short comings, etc??? I know the 2520 had that lucky feature of popping out of 4WD... And many have stated that the dealer advised adding air pressure, counter balance, and the like... All of which were appalling solutions. I would just like to know what I am getting myself in if I go with a 2025R.
Thanks...
   / THinking of a new 2025R... Need some inputs #2
I admit I haven't paid the tractor popping out of 4x4 any attention as I don't have this model. Is this a problem your tractor has? Is there any other reason for trading?
I would be reluctant to trade across as that sounds like lost money imo.
   / THinking of a new 2025R... Need some inputs #3
I would ask myself, what's in it for me? Horsepower and traction are the same in the two models so I can't work faster or easier. I would take a close look at the 2032R and the 2038R.
   / THinking of a new 2025R... Need some inputs #4
I would be unlikely to buy what is essentially the same tractor from a brand that did it wrong the first time. I would also be inclined to go a bit larger, but I don't know your situation.
   / THinking of a new 2025R... Need some inputs #5
I had a 2305 jd but traded it for a 2032R , what a tractor, put a new cozy cab and extra hyds, my opinon.
   / THinking of a new 2025R... Need some inputs #6
A friend of mine just got a new series 2032R and it is a lot huskier than than the old series it replaced, he hasn't used it much yet but isn't sorry he traded.
   / THinking of a new 2025R... Need some inputs #7
After getting the bugs out, 2032r is wonderful.
   / THinking of a new 2025R... Need some inputs #8
That would be a good way to not own anything, I can't think of one manufacturer that hasn't had problems at one point.
Ronnie
   / THinking of a new 2025R... Need some inputs #9
I was looking at the 2025R and the 2032R and glade I went with the 2032R, the extra size and horsepower makes you feel like your on a big tractor while being able to get into tight places, but I have five acres and I don't know your situation.
Thanks for the input... Apparently the 2025 model back then was the only model that had the issue with popping out of 4WD.
My understanding is that labor costs for fixing the 4WD is about 16 hours, $1300 give or take plus materials and parts. Additionally my understanding is that the fix doesn't fix it permanently. If you would have seen my shorts after the last time it popped out, you wouldn't trust that it could be fixed.
My tractor is 6 years old, trading across to an equivalent size/model really isn't an issue considering I would be getting a warranty again.
After talking to the dealer, I am looking at a '17 2032 R. A little bigger, fuel filler is moved to the rear, auto-connect deck.
So yes, I will probably take a loss... But there are several other features to gain.
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2015 DODGE RAM...
2020 KUBOTA RTV...
1991 Mack RW713 Day Cab Truck, VIN # 1M1AY10Y4MM005693 (A51572)
1991 Mack RW713...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
